*************How to improve Throttle Response***************
Old Aug 27, 2008 | 08:47 AM
secrt0007agt's Avatar
secrt0007agt
St. Jude Donor '15
Default *************How to improve Throttle Response***************
I have a stock 99 and the Throttle Response really sucks. I have a predator and mass flow, but what is the key (within reasonable $$) to fixing the issue? Thanks
HEY GUYS, I AM NOT LOOKING TO OVERHAUL OR MAKE MASSIVE MOD'S. I JUST NOTICED THAT MY RESPONSE SEEMED SLOW WHEN I MASHED THE PEDDLE TO THE METAL. ACTUALLY, I CHECKED WITH MY BUDDY AT THE GM DEALERSHIP & HE SUGGESTED TO USE SOME THROTTLE BODY SPRAY CLEANER & CLEAN THE INSIDE AREA OF THE THROTTLE BODY TO INCLUDE THE INSIDE OF THE BUTTERFLY. HE SAID TO USE A TOOTH BRUSH WITH THE SPRAY AS NEEDED TO CLEAN HER OUT GOOD. WELL, IT WORKED LIKE A CHARM--AND HE EVEN GAVE ME A CAN OF CLEANER---RUNS LIKE A NEW CAR!
THANKS FOR THE RESPONSES AND IF I EVER DECIDE TO GO TO THE TRACK, I WILL CONSIDER SOME OF THE REPLIES.
Old Aug 27, 2008 | 09:03 AM
jedblanks's Avatar
jedblanks
It never was a problem when I was stock, but the biggest key for throttle response since I added headers was making sure the o2 sensors are getting the correct reading (probably the maf too). If you have an aftermarket MAF, get rid of it.
LS6 intake helped SOTP tremendously as well.
Old Aug 27, 2008 | 09:15 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
LS6 all the way.
Old Aug 27, 2008 | 09:38 AM
sami85L98's Avatar
sami85L98
Ported TB will give SOTP feel but not sure it will give more ponies, but u can feel it. I installed on my pretty much stock Z and i felt the response immediete.
Old Aug 27, 2008 | 10:28 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Buy a LS6 intake off here or that auction site, have the intake ported and the throttle body ported and polished. You will feel a big difference in throttle response. You should be able to get it done for around $1000 including the tune, which you will need.
Old Aug 27, 2008 | 10:31 AM
black98c5's Avatar
black98c5
Gears!!!!!!!!!!!!!!!
Old Aug 27, 2008 | 11:23 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
put the oe maf back in, ditch the pred.
install a cam/AR headers and get a good tuner, 60plus whp, done.
Old Aug 27, 2008 | 02:30 PM
cmeflibi's Avatar
cmeflibi
yeah I heard gears makes a big Diff especially if your an auto running the 2.73's.
To *************How to improve Throttle Response***************
