LED DRL resistor
Old Aug 27, 2008 | 08:05 PM
bcartman2's Avatar
bcartman2
Default LED DRL resistor
I put some LED llights in my DRL's and I cant stand the rapid flash. What resistance and wattage should I use? thanks for your help
Old Aug 27, 2008 | 10:17 PM
AZ99's Avatar
AZ99
I wouldn't recommend the resistors ," Load Equalizers" or "Load Resistors".generate to much heat and in many cases have melted wiring or other parts. They are generally 15-25 watt metal resistors with metal heat sink designed to be mounted to a metal surface to disipate the heat they generate....on the vettes you don't have many places to mount them to dissipate the heat so they can be hazardous
But if you still want them search for "led load equalizers" and you will more than likely find the values
Old Aug 28, 2008 | 12:10 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Don't do it. Spend the money and buy a flasher bypass harness. I;m sure Richard will see this topic and pop in. The resistors will melt your wiring. Trust me cause I did it in a Jeep Grand.
Old Aug 28, 2008 | 01:34 AM
jdmvette's Avatar
jdmvette
Night Owl for life
resistors are used if you have no other option. luckily the c5 has a wonderful option called the "flasher bypass harness".
look it up.
Old Aug 28, 2008 | 10:56 AM
THE TECH's Avatar
THE TECH
Just get Richard's plug-n-play setup and be done. Some of the best money I've spent.
Old Aug 28, 2008 | 01:59 PM
mtndv8's Avatar
mtndv8
Default Flasher/Bypass Harness
Richard's Harness!
Also helps isolate and/or eliminate any problems associated with light/LED upgrades in the future. my .02...
Aloha
Michael
Old Aug 28, 2008 | 03:41 PM
mcgilles's Avatar
mcgilles
I agree with the above. the problem with the load resistors is that they are designed for turn signals, not DRL's they are intended for a 50% duty cycle max, but with DRL's on your car they will have current running though them constantly.
get a flasher bypass hardness with an LED flasher on it so you have no more hyperflash.
and do yourself a favor and disable the DRLs while you're at it!
Old Aug 28, 2008 | 03:49 PM
WBHighwind's Avatar
WBHighwind
I was one of the first to get the flasher bypass harness and it has worked perfectly from the first moment I installed it. I couldn't have been any easier to install either with its gm style plugs on both ends meaning no cutting or soldiering.
http://forums.corvetteforum.com/show...bypass+flasher
Old Aug 28, 2008 | 09:11 PM
bcartman2's Avatar
bcartman2
Thanks a bunch guys, once again you save my butt. I will order a harness in the morning.
Old Aug 28, 2008 | 11:22 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by WBHighwind
I was one of the first to get the flasher bypass harness...
i got you beat.
To LED DRL resistor
