Window rolled down by itself
Old Aug 29, 2008 | 10:40 AM
RoccoC5's Avatar
RoccoC5
Default Window rolled down by itself
This morning on the way to work, my passenger window went down by itself. It wouldn't respond when I tried to roll it up for a few seconds, and when it did start to go up it went back down as soon as I released the button. After a minute or so it returned to normal operation. What could it be? A bad window switch? Door control module? It rained pretty good last night, and I was unfortunate enough to have to drive in it for a bit. Maybe the water brought out the electrical gremlins?
Old Aug 29, 2008 | 02:41 PM
bestvettever's Avatar
bestvettever
Default Window gremlins
Hi, pull back the accordians that house the wires and connectors between the door and front pillar, and check very closely for a shorted wire or loose connector. Good Luck
Old Aug 29, 2008 | 03:23 PM
liljohnny555's Avatar
liljohnny555
St. Jude Donor '08
water...rain...does strange stuf to my 03 coupe.
Old Aug 29, 2008 | 05:09 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Does it do the same thing when you use the passenger side window switch ?
To Window rolled down by itself
