Maybe you guys can help me out. I installed ACE Slick Z07 18x11 rear and 18x9.5 fronts and now when driving with the traction control ON the car goes into limp mode. When I turn OFF the traction control it drives fine. I have no clue whats going on.
did you keep the same ratio for the height of the tires?
GM designed these cars with the rear tires having a larger diameter and circumference than the front. The traction control is built/calibrated to know that the front tires should be traveling faster than the rear. When the rear tires travel near or faster than the front, the traction control wants to do its thing. My guess is you have front tires with a circumference that is equal to or larger than the rear. Check the codes and see what they are telling you.
That's your problem. Same rolling circumference front and rear. The Traction Control thinks the read tires are loosing traction. Need to reduce the fronts or increase the rears in rolling circumference.....
ie taller tires in the rear or shorter tires in the front
8vette7 is correct. Go to the Tire Rack web site, they have the circumference of all the tires they sell. You need to find the ratio of the circumference of the stock front to rear tires, then find tires with a similar ratio. It does not have to be dead nuts on. On my 18 x 9 1/2 fronts and 18 x 11 rears I ran 265 front and 295 rears. I have since switched to 275/35 and 315/30 using the same rims. Make sure to keep the aspect ratio in mind when you are calculating ratios.
i put 18's all around but 245/40 on front and 275/40 on the back to accommodate stock tire height for front and rear. no problem and might i add that gsd-3's are exceptional tires!
Put a 305 or 315 on the 11 wheel, your problems will go away with a taller rear tire. You are going to wear the rears very quickly and have poor traction with the rear tires set up like that.
