New Injectors??
Old Jan 4, 2002 | 01:45 PM
O-Ace's Avatar
O-Ace
Default New Injectors??
At what HP level does the car need new heavy-duty injectors? Also, post specs on the injectors. Thanks guys! :seeya
Old Jan 4, 2002 | 01:56 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: New Injectors?? (O-Ace)
You injectors should be could to about 450RWHP. Past that I would look at stepping up to 36# SVO injectors.
-Jeremy
Old Jan 4, 2002 | 02:13 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: New Injectors?? (Godspeed)
-Jeremy
Ditto that!
I was fine on stock internal engine on NOS (wet)
If you go NOS dry setup or heds/cam then I would upgrade trhe injectors.
I went with #30 Injectors from Chris@Speeddemonmotorsports for a good price. I think at our fuelpressure they are #36.
Michael
Old Jan 4, 2002 | 02:44 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: New Injectors?? (Austrian Vette)
Michael
That why I went with the NX Wet Kit. And you're correct about the fuel pressure. It's listed as Ford 30# Injectors.
-Tuan
Old Jan 4, 2002 | 02:58 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Another reason besides HP to use larger injectors than needed is to use them in conjunction with a maf translator to increase timing based on perceived engine load.
There more info about that on my site.
Old Jan 4, 2002 | 03:51 PM
O-Ace's Avatar
O-Ace
Thanks for the info! :cheers:
Old Jan 8, 2002 | 10:03 AM
2001roadsterNBM's Avatar
2001roadsterNBM
oace- Are these injecters for your head and camm? When will your package be ready?
Old Jan 8, 2002 | 10:37 AM
TyVette01's Avatar
TyVette01
Default Re: New Injectors?? (2001roadsterNBM)
O-Ace let me know which injecters you are going with your heads and cam as I am planning on that setup in the spring.
Old Jan 8, 2002 | 11:54 AM
O-Ace's Avatar
O-Ace
Yes, they are for the ARE Stage 2 H/C. Car should be ready by the end of this week.
To New Injectors??
