cat sims
Old Sep 3, 2008 | 08:30 AM
blaizebrianna's Avatar
blaizebrianna
Navigator
Default cat sims
Does anyone know where I can get cat sims cause of course after I punched out the cats on my 99 hardtop the engine light went on. Or does anyone have another fix.
Old Sep 3, 2008 | 09:13 AM
John@SDPC's Avatar
0John@SDPC
Former Vendor
You will likely have better luck finding someone to turn off these codes. O2 sims have become a fairly big no-no.
Old Sep 3, 2008 | 10:55 AM
corvettedoctor's Avatar
corvettedoctor
You will not find them unless you can find them used. When the EPA went after Casper for making O2 Sims everybody stopped making them. Even on ebay.
best way is to have a tuner tune them out.
Chris
Old Sep 3, 2008 | 12:21 PM
THE TECH's Avatar
THE TECH
I just picked up a set brand new. If you want the info, you can PM me. I haven't used them yet, but the vendor sells them regularly.
Old Sep 4, 2008 | 12:32 PM
AZ99's Avatar
AZ99
id be carefull with that.....part of caspers deal with the EPA was they had to hand over all of there customers information. I would think that the guys still selling them, if caught would be required to do the same
Old Sep 4, 2008 | 01:35 PM
chpmnsws6's Avatar
chpmnsws6
Why did you punch out your cats? when you do this, you can cause turbulence in the housing making your engine make LESS power. You also wasted 160 dollars you could of made by selling your cats to a scrap broker. Noise does not equal power. If you question that, look at a Harley.
Old Sep 4, 2008 | 01:41 PM
THE TECH's Avatar
THE TECH
I'd disagree with that. I'd bet that the less restriction would outweigh any turbulence caused by punching them out.
THE TECH's Avatar
THE TECH
HIDs are also just as illegal, but people still use them regularly.
Old Sep 4, 2008 | 01:45 PM
chpmnsws6's Avatar
chpmnsws6
Have you ever studied the characteristics of airflow? When a small pipe is introduced to a larger area, it creates a swirling wave pattern because the pressure is reduced and the air is allowed to expand.
To cat sims
