Headlight pin came out???
Old Sep 3, 2008 | 10:44 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Default Headlight pin came out???
Was driving along tonight and all the sudden I see my pass. headlight start to wave up and down and finally go down. Get home and check and find out the pin that goes through the motor bracket came out somehow (below):
Everything is working ok, the motor is still goin up and down like it should so it looks like all I need to do is put this pin back in place but how do ya do that? I can't see the bottom of the headlight of course and I felt around the drivers side but I'm not exactly sure how to put the pin back. Is there any other piece that might have fallen down that I should be aware of?
Thanks for any help!
Old Sep 3, 2008 | 11:32 PM
LoneStarFRC's Avatar
LoneStarFRC
The retainer washer is missing. Maybe broke off or just came off. After re-inserting that pivot pin a flat, spring type lock-washer gets pushed onto the shaft to retain it. The retaining washer is not available from GM as a separate item, however you could just take the pin to the auto parts store or maybe Home Depot and find one of the correct size. It just pushes on over the shaft and is self-locking.
BTW when reinstalling, be sure to leave a little room for a little side-to-side movement of the pin and not make it too tight; otherwise binding may occur from the increased friction.
HTH
FYI, do a search on "HID install". There are a number of posts with pictures of the headlight assemblies in various stages of dis-assembly. A post by jprich has a picture that shows that pivot pin and the retaining washer installed.
HTH
Old Sep 4, 2008 | 12:15 AM
at88mph's Avatar
at88mph
HTH
Thanks A LOT for the info! When I removed the black headlight cover I saw what you were talkin about. I used a bolt w/ a nut that was a little longer than the pin and installed it but didn't tighten it up too much...just snug. The bracket has some wiggle room (compared to the drivers side which is tight with no wiggle in it)
Thanks again!
Old Sep 4, 2008 | 01:08 AM
LoneStarFRC
Thanks again!
Glad to help.
BTW, if you used a bolt/nut, I would advise using a locking type nut (nyloc for example) as it will stay precisely where you tighten it to and not back off causing the same problem again. Also, there is (or was) a white nylon bushing that the pin originally passes through. I hope you still have it installed.
Old Sep 7, 2008 | 12:20 PM
JC in XTC5's Avatar
JC in XTC5
Glad you fixed it. The same thing happened to me a few years ago where the compression washer popped off. Your fix should do fine.
To Headlight pin came out???
