Check engine light is on
Old Sep 5, 2008 | 03:46 AM
OneFastC5's Avatar
OneFastC5
Cruise-In IX Veteran
St. Jude Donor '09
Default Check engine light is on
can changing your tire size cause the check engine light to come on?i just recently went with new wheels from a c6 (stock sizes) and have notice my gas mileage has gone downhill, and now my light has come on.i was reading through my owners manual and it mentioned that changing tire sizes will make my light come on and affect my emissions. if so what do i have to do take it to the dealership and have it reprogrammed?
Bill
Old Sep 5, 2008 | 09:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The tire size is programmed into the PCM. I wouldn't think it would cause the light to come on but this is simple to find out. Pull the codes and post them.
Old Sep 5, 2008 | 11:30 AM
rws.1's Avatar
rws.1
the #1 cause of a check engine light is a loose or faulty gas cap.
Others include problems with the engine running too rich or too lean, a plugged catalytic converter, a bad oxygen sensor or a problem with the evaporative emissions system....
As per the previous post... run your diagnostic codes and post them...
Old Sep 5, 2008 | 11:32 AM
rws.1's Avatar
rws.1
Here is a link to a C5 Tech tip to tell you how to read or pull the diagnostic codes...
https://www.corvetteforum.com/techti...D=25&TopicID=1
Obviously you should write them down before you contemplate deleting them....
dougbfresh's Avatar
dougbfresh
YES tires size changes can make the ABS/TCS NUTS. Get the codes out of the DIC and lets see.
Old Sep 5, 2008 | 12:20 PM
OneFastC5's Avatar
OneFastC5
St. Jude Donor '09
ok heres the code i received. BO-RFA C2120 H C
something easy i hope?
ok just found it!
C2120 TPM System Malfunction (No Sensors Received)
guess i need to get my correct sensors installed thanks guys
Old Sep 5, 2008 | 02:29 PM
dougbfresh's Avatar
dougbfresh
Did you put new ones in?
Old Sep 5, 2008 | 03:33 PM
OneFastC5's Avatar
OneFastC5
St. Jude Donor '09
went with c6 wheels already mounted on tires and just didnt switch the sensors yet
Old Sep 5, 2008 | 03:52 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
ok just found it!
This won't cause a "check engine" light, there will be a code after the PCM
Old Sep 5, 2008 | 04:45 PM
dougbfresh's Avatar
dougbfresh
It did, lot's of things will set the Check Engine Light that have nothing to do with the engine directly. Had mine set when My Skip Shift eliminator broke.
To Check engine light is on
