In line resistor????
Old Sep 6, 2008 | 01:03 PM
LT1vette's Avatar
LT1vette
Default In line resistor????
Do I need to install a resistor on a 99 when converting to HID lighs? They are 35W, made by Galaxy Power.............The instructions ONLY talk of upgrading the 15W fuse to 20W.............
TIA
Old Sep 6, 2008 | 02:02 PM
T.J.'s Avatar
T.J.
I bought one for my 97. Just make sure you have a full charge when testing.
Old Sep 6, 2008 | 09:31 PM
minitech's Avatar
minitech
You need it with some and not with others. The issue is the headlight doors don't close when you turn the lights off. Change to high beam for a second to close them.
There is a vendor here that sells a very nice in-line resistor that fixes the problem. Completely plug and play for about $15.00
I'd install them and if needed buy the resistor.
Old Sep 7, 2008 | 10:18 PM
LT1vette's Avatar
LT1vette
Default Anyone have this problem....
Has anyone had a this problem with a 99 specifically? Or is it some cars need the resistor and some don't?
TIA
Old Sep 7, 2008 | 11:53 PM
rws.1's Avatar
rws.1
No resistor needed in my '01
Old Sep 8, 2008 | 02:25 PM
LT1vette's Avatar
LT1vette
Default Forum Vendor with in line relay/resistor
I saw this ad in here the other day and no I can't find the link to it.
Vendor had in line relay/resistor for headlights on sale for $15-16..........
Anyone know who the vendor was???????????
THX
Old Sep 8, 2008 | 03:27 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Go here and order a pair of 10watt, 50 ohm resistors wire wound resistors. 1.50 each.
http://www.surplussales.com/Resistor.../WW50-110.html
Old Sep 8, 2008 | 11:15 PM
T.J.'s Avatar
T.J.
U can always buy it from the bay.
Old Sep 9, 2008 | 10:15 AM
minitech's Avatar
minitech
The one from the vendor here is plug and play though. Right connectors and is in a heavy heat sink case. Impressive quality. And for $15.00 not worth looking anywhere else or trying to get something to work in with cutting your wires.
And it is best to support forum vendors!
To In line resistor????
