PCM install
Old Sep 8, 2008 | 07:50 PM
lomoman's Avatar
lomoman
Default PCM install
Any tips installing a PCM? The manual says its somewhere behind (or under) the battery. Thanks in advance.
Old Sep 8, 2008 | 07:55 PM
byronhunter's Avatar
byronhunter
Remove the right front tire, then open the closeout panel at the back of the wheelwell. (DON'T FORGET TO DISCONNECT THE BATTERY FIRST)
Old Sep 8, 2008 | 10:01 PM
lomoman's Avatar
lomoman
Thanks...Any re-learning sequence or is it plug n go
Old Sep 8, 2008 | 10:17 PM
Fast Cop's Avatar
Fast Cop
You do have to get the new PCM programmed to your vin. Once it is programmed to your vin I believe it is a plug and play, others will chime in if its not.
To PCM install
