transmission noise
Old Sep 8, 2008 | 09:13 PM
1320IN9's Avatar
1320IN9
Default transmission noise
i was parked in a real quiet area tonight and just happened to notice that when i shut the car off i get a rattle type sound from under the shift boot area, so i started it back up and turned it off again and it made the same noise, so i start it back up with the clutch out i give it just a touch of throttle and i hear the rattle/ vibrate noise again each time i give it just that amount of throttle but when i give it more throttle it wont make the noise, is it the throwout bearing? i know the t-56 is a loud noise maker but i dont remember hearing it that much..
Old Sep 9, 2008 | 03:11 PM
BELVIN20's Avatar
BELVIN20
Normal C-5 trans, clutch-rattle, when you get in a enclosed garge area, you hear a lot of noise amplified by being between walls. My C-5 MN6 sounds like a bunch of marbles rolling around since I bought it when it had 6000 miles, now has 41k and same marbles rolling around in it, I think most will agree the noise is all normal, and C-6 MN6 make all the same noise.
Old Sep 9, 2008 | 03:56 PM
Robls6's Avatar
Robls6
It's normal. Push the clutch in while shutting the car off and it will keep the torque tube from spinning while shutting down.
Old Sep 9, 2008 | 08:49 PM
1320IN9's Avatar
1320IN9
yeah, i figured it was nothing, just amplified by the place i was parking, made it sound 10 times worse..
To transmission noise
