side molding question
Old Sep 8, 2008 | 11:24 PM
johnnyzvette's Avatar
johnnyzvette
Default side molding question
What's the best way to remove the side molding from my car?
Old Sep 9, 2008 | 10:59 AM
jarsdad1's Avatar
jarsdad1
Search is your friend.
http://forums.corvetteforum.com/show...olding+removal
Old Sep 9, 2008 | 12:53 PM
clif's Avatar
clif
St. Jude Donor '09-'10
this link is bad.... I get a 404 error...
Old Sep 9, 2008 | 01:08 PM
hotwheels57's Avatar
hotwheels57
Search is still your best friend as this gets discussed often.
Go to C5 Tech. Click on search or search this forum (in the red banner).
Use keywords "bsm removal" or "body side molding removal".
You'll have plenty to read...
Old Sep 9, 2008 | 02:03 PM
patrickC5's Avatar
patrickC5
Heat gun and fishing line worked for me.
Old Sep 9, 2008 | 02:09 PM
slothy's Avatar
slothy
i used heat gun + wd40 and fishing string.
Old Sep 9, 2008 | 02:25 PM
powderski13's Avatar
powderski13
I used a heater to warm the entire side of the car then used fisshing line to start. I then pulled them off using a soft plastic body filler piece to cut the glue. Worked great. Keep the surface warm to make glue removal easier.
Old Sep 10, 2008 | 10:26 AM
johnnyzvette
thanks, i appreciate all the replies. I got them off, however I can still see the outline of where they were. Maybe some more elbow grease will get it out.
Old Sep 10, 2008 | 04:19 PM
patrickC5's Avatar
patrickC5
The line "should" buff out.
To side molding question
