What do you guys think of this upgrade? I have a 2002 coupe with base suspension, wanna go to: Bilstein Sport Shocks (Z51) front and rear, BMR sway bars (32mm front, 19mm rear) and keep stock monoleaf. Car is already lowered on stock bolts (1-1 1/4in). I have stock size non-runflats in front and 285/40 555Nitto 18's in rear.
I just went to gene cully and bought c6 z06 shocks and c5 z06 sway bars. Total was under 6 hundred and the difference was immeasurable, except in happiness.
I'd look at www.pfadtracing.com They have some nice sport bars. Or Hotchkis. Still, I'm sure you will be happy with what you have selected. But it doesn't hurt to look some more.
I did Hotchkis bars, they did help. But, the improvement in ride from the C6 Z06 shocks was a shock so to speak.
I'd keep your spring, only change it when you NEED to IMO.
Wow, so the C6Z06 shocks fit a C5? How much they go for? Gotta look into that. Ive looked at the Hotchkins too but I just fell for the Mid America setup. Its there own setup made by ADDCO with a lifetime warranty and the front is 35mm and the rear is 25.4mm, thats huge. Its a road race setup and its going for $440 frnt + rear. Its a chromoly tubular construction, they look pretty beefy.
They have the C6 Z06 shocks and even the C6 z51 bars, both of which work on the C5 and are very cheap.
I would be a little concerned with the heim jointed end links, they can be very noisy. A loud knock when turning when the heim joint slips. They may be OK, but hard to tell. Hotchkis re-worked theirs and is suppose to be quieter, but I just went with the GM metal end links, no noise.
Something seems off with those BMR bar sizes. 32mm vs 19mm is too big a spread. Typical sizes should be around 32mm vs 26mm or so unless one of the bars is hollow or completely different than a stock style or something like that. I think stock is 19mm on the rear.
As already posted, the C6Z06 shocks and C5Z51 bars are a good choice that won't disappoint and they're as cheap an upgrade as you can get buying new parts.
Thnx guys. Called dealer and all 4 C6 Z06 shocks are about $400, thats not too bad. I went to GMParts House but couldnt find the parts, just a list of prices for other stuff. Anyone have a link to the page with the shocks and sway bars? Thnx again guys, sounds like the C6 stuff kicks *** and is cheaper. Sounds good to me.
EEEEK! $400 is waaaaay high. GM Parts Direct has all four for $236.
Just type c6z06shocks under Chevrolet make to order a full set of them at that price.
Just found the part numbers for the c6 z06 shocks and sway bars. Both come in kits and I can get all for around $450! Thnx guys, I didnt know of this site, what a life saver!
Hey guys, whats better, the C6 Z06 shocks or the C6 Z51 shocks? I guessing the Z06 but just wanna make sure. anyone have the sway bar sizes for the C6 Z06? Thnx.
BTW, Gene Cully works at GMpartshouse, right? That way I'll ask for him.
Get the C6 Z06 shocks and yes, Gene works at GM Parts Direct. Sorry, not up on the C6 sways.
Thnx for all the advice guys. I should have my setup complete around the end of Nov. I def let you guys know what I went with and how it feels. Thnx again.
