Column lock bypass question?
Old Jan 5, 2002 | 04:21 PM
Fenderman's Avatar
Fenderman
Default Column lock bypass question?
Why install one of these? Just curious.
Old Jan 5, 2002 | 06:45 PM
Sniper168gr's Avatar
Sniper168gr
Default Re: Column lock bypass question? (Fenderman)
The pin fails to retract from the column and leaves you stranded. Happens at the worst possbile time... of course! :mad
Old Jan 5, 2002 | 11:57 PM
Fenderman's Avatar
Fenderman
Default Re: Column lock bypass question? (Sniper168gr)
Thanks for the reply. Does this happen frequently? This must be an anti-theft feature of the car.
Old Jan 6, 2002 | 11:25 AM
Sniper168gr
You are correct in that this is anti theft feature. Up to and including 2001 I believe there was a problem. I received a recall notice from GM to have it fixed, but ended up installing the CLB myself. I believe since you have a 2002 there is nothing for you to worry about. :)
You can do a search from the forum page if you want more background info. Welcome to the C5 family.
[Modified by Sniper168gr, 10:26 AM 1/6/2002]
Old Jan 6, 2002 | 12:31 PM
carpe dm's Avatar
carpe dm
There have been many posts by folks who have had their steering "lock" on them; some at very inconvenient times! (When would it be convenient?) It is a good problem to avoid....... :eek: :yesnod:
To Column lock bypass question?
