Shifting lesson
Old Jan 5, 2002 | 07:29 PM
viperZ06's Avatar
viperZ06
Default Shifting lesson
I posted about frequently missing 3rd gear when shifting rapidly on the forum. The convential wisdom I rec'd was not to grip the stick when going to 3rd gear but to push the stick with the heel of my palm. I tried it and it works great. Have not missed third again. Sould work even better with my Kirban which is being installed next week! Thanks forum, Any other hints? :cheers:
Old Jan 6, 2002 | 12:17 AM
John Wiz's Avatar
John Wiz
Default Re: Shifting lesson (kgrif)
When you shift into 4th, keep your thumb pointed down. If you grab the shifter with your thumb pointed up (as a lot of people do, the pistol type grip) you have a tendancy to pull the shifter toward you. This can lead to the dreaded 3-2 shift when running hard (and can lead to the dreaded bent pushrods). Try it and see.
Wiz
Old Jan 6, 2002 | 12:48 AM
chuckster's Avatar
chuckster
Welcome to the 3rd gear PUSHERS club. Remember...never try to FIND 3rd. Just jam it up.
:cheers:
[Modified by chuckster, 10:49 PM 1/5/2002]
Old Jan 6, 2002 | 10:56 AM
geekracer's Avatar
geekracer
The issue is shifting from 3rd to 4th and accidently hitting 2nd instead.
Old Jan 6, 2002 | 11:10 AM
chuckster's Avatar
chuckster
Default Re: Shifting lesson (MMarquez)
If you shift to 4th the same way you hit 3rd then you should NEVER hit 2nd. I can see hitting 2nd trying to get to 4th from 6th. The centering spring keeps the stick lined up with 3rd and 4th. :cheers:
Old Jan 6, 2002 | 12:44 PM
HGlide82's Avatar
HGlide82
Sometimes I have the problem of missing 3rd. I'm going to start pushing with my palm when going into 3rd. I don''t think I've even been going fast enough to aggressivly shift into 4th, but maybe someday... :)
Old Jan 6, 2002 | 03:54 PM
MelloYellow's Avatar
MelloYellow
Default Re: Shifting lesson (HGlide82)
There are common Hydraulic backup problems when shifting into 3rd after progressive hi-rpm redline shifts. The modified M/C line addresses this problem. Makes a HUGE feel difference. Return hydraulic pressure is Awesome. Feels like a totally different clutch system. A quality one vs. a GM POS. GM added a line restriction in the middle to soften shock to the drivetrain and increase clutch slippage/wear.
Old Jan 6, 2002 | 11:02 PM
viperZ06's Avatar
viperZ06
Default Re: Shifting lesson (MelloYellow)
Describe this MC thing please. I don't know what you mean. Is there a fix?
Old Jan 7, 2002 | 12:19 AM
Patman36's Avatar
Patman36
I will have to try this out. :cheers: Be sure to let us know how you like the Kirban. I have tried a Ripper and it was WAY too stiff for me and I am not about to jump on the Hurst-wait bandwagon. :lol: :D :cheers:
Patrick :seeya
Old Jan 7, 2002 | 12:32 AM
MelloYellow
http://forums.corvetteforum.com/zerothread?id=192593
Your choice with or without the Slave Quick Disco.
Old Jan 7, 2002 | 10:00 PM
viperZ06's Avatar
viperZ06
Thanks I will look into it. :seeya
Old Jan 8, 2002 | 12:07 AM
RD_STIR's Avatar
RD_STIR
7th Gear
I have the B&M Ripper. the centering springs are tight, but that's the price you pay for never making the 3 to 2 shift/bent rods mistake at high RPM :p:
Old Jan 8, 2002 | 01:42 AM
MelloYellow
Default Re: Shifting lesson (RD_STIR)
The newer B&M's aren't as tight. Might want to get a new one from LAPD for $160. Not that expensive. I'm sure you can sell yours used. Sold my older B&M very fast. Actually within 30 minutes of coming out of the car!! ;)
To Shifting lesson
