code 10-PCM
Old Sep 10, 2008 | 08:08 PM
jakestyr's Avatar
jakestyr
Default code 10-PCM
I keep getting the code 10-PCM -- Does anyone know what that is?
Old Sep 10, 2008 | 08:35 PM
Bill Dearborn's Avatar
Bill Dearborn
10-PCM is the category for PCM codes. It is always there. You have to display the codes that are within that category. First Push and Hold Options then while holding the Options button push the fuel button 4 times. The car will go into diagnostic mode and will proceed to the 10-PCM category first. If there are any codes it will flash each one of them for several seconds. When it finishes that category it goes to 20-TCS next.
Bill
Old Sep 10, 2008 | 09:38 PM
sami85L98's Avatar
sami85L98
Most definetly P0420 or P0430, a less efficient rear O2 sensor problem, which most of em here get it after header install, yep Bill has said it clearly, its the category u need to see the codes listed in that 10-pcm headings.
Old Sep 11, 2008 | 01:34 AM
striper's Avatar
striper
Have you recently installed long tube headers and deleted the rear O2 sensors? Sounds like it. You need a tuner to delete the O2's from your computer. If that's not the case, the other common problem relates to a fault in the air pump system.
To code 10-PCM
