Traction control causing erratic AF ratios?
Old Sep 11, 2008 | 12:48 AM
TurboTravis's Avatar
TurboTravis
Default Traction control causing erratic AF ratios?
Long shot, but does anyone know if having the traction control on would cause erratic AF ratios? I'm troubleshooting erratic and inconsistant AF ratios on my car and it's down to either the actual sensor control box (FJO) or the traction control. The car was on the dyno recently and the AF ratios were consistant on the dyno, but we did have the traction control off on the dyno.
Travis
Old Sep 11, 2008 | 07:35 AM
TurboTravis
Originally Posted by Z06supercharged
I always drive with TC off. I did however forget 2 times this last week to turn it off and when hitting 2nd gear and spinning a little the car nosed over horribly when the TC activated. It did it at the top of 2nd also when tires spun. I hated TC when I was NA and hate it even more with the s/c as it really upsets the engine bad.
I know the feeling. I'm just somehow doubting that the car is pulling fuel to control tire spin. Can't get a strait answer though..
Old Sep 11, 2008 | 01:54 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Maybe it's triggering your burst knock retard. Try disabling the burst knock and see if it gets better.
Old Sep 11, 2008 | 05:32 PM
redcycle13's Avatar
redcycle13
I don't know how it effects A/F but I can tell you that it does. I was logging my car while pushing it hard in comp mode, and it was somehow making the A/F ratio very lean on the log chart. I had a friend tell me it was the traction control system, and I didn't believe it, but when I logged it again with traction control off the A/F ratio was right on with what it had been on the dyno a few days before.
Old Sep 16, 2008 | 03:17 PM
Scubanme's Avatar
Scubanme
The tractioncontrol/active handling works with the ABS system.
Old Sep 17, 2008 | 05:10 PM
redcycle13's Avatar
redcycle13
It does work with the ABS, but on my logs when it kicks in it also pulls back a % of throttle. I guess this it what causes things to lean out in the log.
Old Sep 17, 2008 | 05:38 PM
Bill Dearborn's Avatar
Bill Dearborn
When tire spin goes beyond a certain dead band range in the EBCM it requests a torque reduction from the PCM. From the Service Manual:
When drive wheel slip is noted while the brake is not applied, the EBCM will enter traction control mode.
First, the EBCM requests the PCM to reduce the amount of torque to the drive wheels via the requested torque signal circuit. The PCM reduces torque to the drive wheels by retarding spark timing and turning off fuel injectors. The PCM reports the amount torque delivered to the drive wheels via the delivered torque signal circuit.
Bill
To Traction control causing erratic AF ratios?
