My Blinker!
Old Sep 11, 2008 | 08:18 PM
pokeyjones's Avatar
pokeyjones
Default My Blinker!
Front pass turn signal bulb out, easiest access point to replace? I know there is search, figured I'd get some style advice at the same time... 1999 FRC
Rims pictured are growing on me. Advice on stripping them and powder coat or flat black paint?
I'm a noob, take it easy
Thus far these are the favorite rims. Thoughts?
Old Sep 11, 2008 | 11:39 PM
rws.1's Avatar
rws.1
depends on the girth and length of your arms...
easiest... thru the brake duct... push in and down on the accordian like duct.move it out of the way then reach up and feel for the bulb. typical squeeze and twist
next easiest, raise the headlights manually, remove the black plastic bezel from around the headlights, reach in and down. find the bulb squeeze and twist
if you have short thick arms, drive onto ramps or jack the car. from underneath remove the 5 ( 6 or 7 mm bolts) than hold the plastic access panel in place
Once removed you can see the directional bulbs and the foglight bulbs..
Old Sep 13, 2008 | 03:36 PM
pokeyjones's Avatar
pokeyjones
thanks rws.1
surgery tomorrow. i'm 6'1" 180, hoping for easiest.
To My Blinker!
