I got this from my nephew. He got my Annie recently (I got a '64 roadster to replace it). If you can help, I would appreaciate it.
I got a little anxious today and decided to replace the rotors and pads on the Vette with the new ones I got. I got the fronts on no problem but I, for the life of me, can not get the rear rotors off of the car. I've tried everything I can think of without having to bash them off with a sledge. I must be missing something. I have tried to google some help for the last hour or so and can not find any help anywhere. I keep reading things about drilling out rivets(??), pressing hubs, just plain releasing the e-brake(obviously did that), etc....
Not sure if this will help, but it shows how the whole emerg brake, hub assy comes apart. It will definitely help with reassy. Most likely, he needs to turn the "star wheel" on the e-brake to loosen it up. http://forums.corvetteforum.com/show....php?t=2004844
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I sprayed A LOT of liquid wrench and everything else I could find. Then beat on the back of the rotor with a rubber mallet all evening with no luck. Then someone posted to use a ball peen hammer on the back of it. I hit the back at the 12, 3, 6 and 9 o'clock area and it fell right off.
Good Luck,
Jeff
Is it siezed or does it give a little? If its siezed it might be rusted onto the hub. If so, you can use a bolt and stick it into the threaded insert on the rotor to force it off.
If it gives a little, it's probably hung up no the parking brake shoes. It can be a PITA!
2 things, the early (c3's and earlier) used spring steel retainers to hold the rotor on while the car was on the line so the rotors didn't fall on peoples heads as they went down the line. They have to be cut off to remove the rotor if they have never been off. The rears on the IRS cars were RIVETED ON THE AXLE, these rivets need to be drilled out to get the rotor off.
There are still times you need to adjust down the EBrakes to get the drum part of the rotor past the old shoes.
