ported my LS2 throttle body
Old Sep 13, 2008 | 02:31 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Default ported my LS2 throttle body
I didn't remove a lot of material, basically just removed all the sharp edges on the inlet side and then smoothed everything with a 180 grit flap wheel. What do you think? This is my first effort at an LS2 and didn't want to remove too much material because I've heard it'll cause a high idle?
Old Sep 13, 2008 | 03:17 PM
NatesC5's Avatar
NatesC5
Looks great... nice work Mark!
Old Sep 13, 2008 | 03:20 PM
Pumba's Avatar
Pumba
Mark,
Have you driven your Vette with the ported throttle body yet?
Have you noticed any change in driveability, throttle response, and/or performance?
Old Sep 13, 2008 | 03:31 PM
VIPERBLUELX
Unfortunately I don't have an intake to bolt it to, LOL. I've been holding out to see if the Weiand will be released, if not I'm going to pick up a used FAST 90 and port it myself.
Or if I could get gains like you did I might go with the TPIS modded LS6.
Old Sep 13, 2008 | 05:48 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
It looks like there's a slight gap around the throttle blade.... That's the one area that isn't supposed to be touched AT ALL....
It's the air getting past that blade that causes the high idle.
Old Sep 13, 2008 | 06:13 PM
VIPERBLUELX
I stopped porting 1/2" before the blade. If you push the blade shut it's all flush, for some reason the tb blade is slightly open when there's no power hooked to it I guess.
To ported my LS2 throttle body
