Engine codes
Old Sep 14, 2008 | 10:41 PM
jam1192's Avatar
jam1192
Default Engine codes
Can anybody tell me how to check engine codes that show up on my display or reset them. Thank you
Old Sep 14, 2008 | 10:52 PM
aleadfoot's Avatar
aleadfoot
YO Yardley!
I am nearby! The codes are displayed if while holding down button 4 options you press 4x quickley the Fuel button #1. Let the codes run until manual then scroll thru the sections by pressing and releasing the options button. When a code is encountered press and hold reset until it resets. In oreder to know what the codes mean post them up for automatic read or there are listings of the codes do a search. I recommend buyintg the three volume service manual. Have Fun Go EAGLES think we are gonna romp them cowboys monday night? How can you get TO to shut up.
Old Sep 14, 2008 | 11:05 PM
sami85L98's Avatar
sami85L98
Check tech Section:
https://www.corvetteforum.com/techti....php?TopicID=1
Turn ON Ign but no start.
Its simple. Press n hold options button, and at the same time press Fuel 4 times, codes will start display, after a min, it says manual diagnostics something like that, now its time to clear codes (if any),
For ex:
10-pcm 2 codes
(that means u have 2 error codes), to clear just press RESET button till u hear a beep sound or it disappears, and says no codes. So on .
To exit simply press reset button or just turn OFF key and restart car to see if codes cleared.
Old Sep 14, 2008 | 11:06 PM
jam1192's Avatar
jam1192
Originally Posted by aleadfoot
YO Yardley!
Thanks EAGLES all the way
Old Sep 14, 2008 | 11:09 PM
jam1192's Avatar
jam1192
Originally Posted by sami85L98
Check tech Section:
For ex:
10-pcm 2 codes
To Engine codes
