How to reprogram my KEYLESS ENTRY????
Old Jan 6, 2002 | 09:52 PM
Fivo Killer's Avatar
Fivo Killer
Default How to reprogram my KEYLESS ENTRY????
I know you hold down lock and unlock at the same time. But after it honks, then what? Is it set? I did it last night, it worked. But when I came back out, it didnt work. Am I doing something wrong? Please help.
Old Jan 6, 2002 | 11:25 PM
Scott01C5's Avatar
Scott01C5
Default Re: How to reprogram my KEYLESS ENTRY???? (Fivo Killer)
my dealer told me the only way to program them was to bring them in. Of course, they might not have known their heads from their asses
Old Jan 6, 2002 | 11:54 PM
bruce1's Avatar
bruce1
Check your manual, it tells all.
You have to go into set up mode............
see the manual
Old Jan 7, 2002 | 12:14 AM
Patman36's Avatar
Patman36
Default Re: How to reprogram my KEYLESS ENTRY???? (bruce1)
From my manual:
1) Turn ignition to ON
2) Clear any DTC codes by pressing reset
3) Press OPTIONS on DIC until you get to a blank page. Hold Reset for two seconds.
4) When FOB TRAINING is displayed, press RESET button once. The message HOLD LK + UNLK 1ST FOB will be displayed.
5) Hold lock and unlock on the first fob for five seconds.
6) DIC should say FOB LEARNED
7) Repeat 5-6 for other transmitters
:cheers:
Patrick :seeya
Old Jan 7, 2002 | 01:32 AM
murnutz's Avatar
murnutz
Fivo,
You may need to have your fob replaced. My fobs would do the same thing along with doors locking and unlocking on their own even though I had the passive turned off. No problem since I got new fobs!
Old Jan 7, 2002 | 09:21 AM
rwlc5's Avatar
rwlc5
Default Re: How to reprogram my KEYLESS ENTRY???? (murnutz)
If you need to replace your fobs, check out ebay first. I picked one up for $31.00. You just have to make sure that the numbers on the back of the fob you are buying match the numbers on your existing fob. Then just program it according to the manual instructions. If you want, email me and I'll send you the name of the person I got mine from.
Old Jan 7, 2002 | 10:31 PM
geekracer's Avatar
geekracer
Default Re: How to reprogram my KEYLESS ENTRY???? (Patman36)
From my manual:
:cheers:
Patrick :seeya
I believe that this is the procedure to train the car on which FOB is #1, #2, #3 for the memory package. I have just held the lock and unlock buttons until the beep when removing the battery.
Old Jan 7, 2002 | 10:33 PM
Fivo Killer
Default Re: How to reprogram my KEYLESS ENTRY???? (MMarquez)
Okay. So far I have done that. I hold it until it beeps. Then after it beeps, what do I do??? Am I supposed to hit another button. I have done it four times. And after I walk away, it doesnt work anymore. Is there something I am doing wrong???
Old Jan 7, 2002 | 11:43 PM
RD_STIR's Avatar
RD_STIR
7th Gear
My key FOB acted up then stopped working. Got a new battery. Followed procedure from manual - as above. Works like a charm :)
Old Jan 8, 2002 | 12:48 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: How to reprogram my KEYLESS ENTRY???? (RD_STIR)
Hi all,
Fivo Killer, I have the same problem with my FOB. I don't know what's up with it, but I'm going to go try the retrain deal. I was told when I posted a similar question months ago to clean the contacts where the battery touches them inside the FOB and also MAKE SURE the contacts are ACTUALLY touching the battery inside the FOB. I think when they start doing this, the circuit boards inside are fried. Time for a new $100 piece of plastic :mad Maybe it's just been dropped one too many times like mine. :(
Steve
Old Jan 8, 2002 | 08:27 AM
geekracer's Avatar
geekracer
Do you have another FOB? You might try a different one to make sure that the car is ok. If so, then it's probably the battery in your FOB.
Old Jan 8, 2002 | 08:54 AM
skydive69's Avatar
skydive69
Follow the instructions that were typed from the manual. It works - I had to program a FOB this past weekend, and I followed the procedure in the manual. As they often say, RTFM! :D
To How to reprogram my KEYLESS ENTRY????
