code help , please
Ted
DIC Onboard Diagnostics Show DTCs U1016, U1064 and U1096 in History #PI00043 - (Jun 19, 2002)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
DTCs U1016, U1064 and U1096 may be present when scrolling through the onboard diagnostics via the instrument cluster Driver Information Center (DIC).
Recommendation/Instructions:
This is a normal software function as long as the DTCs have a history status upon ignition cycling. No repair attempts should be made.
