Headlight buckets remain up after installing HID conversion kit
Old Sep 21, 2008 | 10:14 PM
boerio's Avatar
boerio
Default Headlight buckets remain up after installing HID conversion kit
This evening, I tried to get the 6k HID conversion kit installed from DJ Motorsport. After following the instructions, the headlight buckets remain in the up position, and when I pull the key from the ignition, I'm getting dong'd.
I've got a 2001 Z06, and the instructions suggested upgrading the fuses from 10a to 20a. But that didn't cure the problem either.
Anyone have any suggestions? Otherwise, I'll call DJ in the morning.
Thanks,
Jeff
Old Sep 21, 2008 | 10:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks,
Jeff
Turn on your high beams and then turn off lights. The ballast screw up the resistance.
Some CF vendor is selling a fix for this, do a search.
Old Sep 21, 2008 | 11:09 PM
boerio's Avatar
boerio
Thanks. This appears to "fix" the problem.
Also, DJ has already been in touch with me. We'll see where it goes!
Jeff
Old Sep 22, 2008 | 09:56 AM
p_dubya's Avatar
p_dubya
you may not have to buy anything!
When i did my HID's i noticed that my headlights would stay up when i turned the lights off...but only when the car was off. If i turn the headlights off while the car is still running, they go down like they should. To get them down with the car off, you just need to turn on you highbeams.
good luck!
Old Sep 22, 2008 | 11:30 AM
Bluefire's Avatar
Bluefire
Jeff,
The problem is the "new electrical" load that the system now sees. The vehicle monitors the electrical load to determine if a bulb has gone out. If it thinks a bulb is out the lights will not close. The system can be fooled by playing with the high beams at times. I installed a relay harness when I installed my ACA HID's. The coil of the relay on this harness is power by the stock OEM headlight connector. This relay coil presents a load to the system that is similar to the stock headlights and the system operates normally. The power to the HID's now come from the contacts of this relay which connect directly to your battery.
HTH
Old Sep 22, 2008 | 12:38 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Jeff
Davis or Dave WILL take care of you......they really know their stuff and are supremely customer oriented
Old Sep 22, 2008 | 12:43 PM
boerio's Avatar
boerio
I have no doubt. It's the primary reason I bought the kit from them - their reputation Will post the result when all is said and done.
Jeff
Old Sep 22, 2008 | 06:46 PM
Bluefire's Avatar
Bluefire
Jeff
I also bought mine from DJ's. I am curious to hear what they say will remedy this.
Old Sep 22, 2008 | 11:13 PM
T.J.'s Avatar
T.J.
Just buy the relay, it will take care of this. Make sure you have a good charge on your battery when testing.
Old Sep 23, 2008 | 10:29 PM
boerio's Avatar
boerio
Heard from DJ. He's sending me a relay. I knew he'd step up.
Jeff
Old Sep 24, 2008 | 09:48 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Jeff
Jeff, you contacted us at 9:15 pm sunday; we replied at 9:47pm sunday and shipped the resistor on monday to you. Just plug it in between the ballast and the car power. You only need to put one resistor on either side. Here's the video for reference.
http://forums.corvetteforum.com/show....php?t=2093653
p.s. You ordered your kit on 8/12 and we were including the resistor at that time. Check your box again..under the plastic tray. If it's there and you end up with two just pay one forward to someone who needs it.
David
Old Sep 24, 2008 | 12:33 PM
boerio's Avatar
boerio
David
David,
Yeah, I was impressed that you got back to me on a Sunday night
I did discover the resistor under the plastic tray. Didn't have much of a reason to look there
Thanks again.
Jeff
So, anyone need a resistor?
To Headlight buckets remain up after installing HID conversion kit
