TPMS o rings???
Old Sep 22, 2008 | 10:48 AM
okbkvette's Avatar
okbkvette
Default TPMS o rings???
ok, I bought some extra tpms from Gene (thanks Gene!) and plan to mount them on my extra black z06 motorsport knockoffs. I'm tired of hitting the reset button and want the security of knowing what the heck the pressure is.
I've seen some things on the forum that on some wheels, folks talk about buying a certain size 0 ring from home depot or wherever.
does this always have to be done? Do they come with it?
Old Sep 22, 2008 | 12:35 PM
Russ K's Avatar
Russ K
The new TPMS sensors come with the grommets installed. Replacement grommets are available
separately under GM part # 25715243.
Russ Kemp
Old Sep 22, 2008 | 12:53 PM
japc5's Avatar
japc5
I am pretty sure it is a #9 O-Ring.
Old Sep 22, 2008 | 06:31 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The 01-04 style sensors do not use an O-ring. The new style sensors will come with the (reusable) rubber washers already installed.
Old Sep 22, 2008 | 07:39 PM
tsts's Avatar
tsts
http://forums.corvetteforum.com/show...58&highlight=9
Old Sep 22, 2008 | 07:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The guy that posted that question in your link has a 2000.
1997-2000 sensors do use O-rings.
The OP here has a 2004 (as indicated in his profile), and as I stated, the 2001-2004 style sensors do not use O-rings.
Old Sep 22, 2008 | 11:34 PM
okbkvette's Avatar
okbkvette
Thanks all, sounds like i'm good to go!
Old Sep 23, 2008 | 08:49 PM
tsts's Avatar
tsts
My previous car was a '99 coupe and it used the "O" rings I mentioned.
You are correct about '01 to '04:
Take a lap around the lake then shoot up 83 and have a good breakfast at the Erin Motel just North of "Q" on the left.(watch those speed limits passing thru North Lake!)
To TPMS o rings???
