Breathless Performance Shifter 15% Discount One Week Only
Old Sep 22, 2008 | 03:18 PM
bpproducts's Avatar
bpproducts
Default Breathless Performance Shifter 15% Discount One Week Only
1997 & Up Corvette Corvette 6 SP Custom Shifter
Breathless Performance Products 1997 & Up Corvette-Precision machined aluminum shifter provides you with the ultimate in speed shifting and comfort. Through years of testing we have designed a shifter to match your driving style. This shifter comes with either a straight or angled shaft. The angle shaft has can go either 2" or 1" back or forward. Also in the kit we include a wedge enabling you to position the shaft 5 degrees toward the drivers side or straight up and also reducing vibration. Reduction of vibration is done by using a special plastic as the wedge. We also supply you with a extra set of springs ( Softer ) for those wanting that softer feel. Please specify shaft needed, either straight or angled.
http://www.breathlessperformance.com...ts/100-262.asp
Item 100-262 $ 229.00- %15 = $194.65
Nalanie
954-925-7725
