Pics needed: 97 coil pack on ZO6 bracket
Old Sep 23, 2008 | 01:53 AM
T.J.'s Avatar
T.J.
Default Pics needed: 97 coil pack on ZO6 bracket
I did a search and couldn't find any pics. I'm putting everything back together after head swap, but can't get one coil pack on each side to line up right. Looking for pics to get a better idea of what I'm doing wrong. Also, need to know what to use to attach to the non-threaded bolt holes for the packs?
Old Sep 23, 2008 | 08:52 AM
Rob Petyo's Avatar
Rob Petyo
need a little more info...
are you still using the "97" valve covers?
My 98 coil packs attached directly to the cover, when I replaced the heads, I needed to also replace the valve covers to be able to attach a "bracket" for the coils, and this sounds like it's your case also.
one has perimeter bolts and the other has center ones.
Old Sep 23, 2008 | 09:19 AM
vsocks1's Avatar
vsocks1
Coil pack brackets mount onto the proper valve covers with bolts through non threaded coil bracket holes.
Old Sep 23, 2008 | 01:18 PM
T.J.'s Avatar
T.J.
I have the new valve covers and brackets, but the coil packs don't fit. I'll have to look at them again to see if they are on upside down or something. The valve covers seem to fit into place, but one pack on each side doesn't fit correctly.
Old Sep 23, 2008 | 02:34 PM
Rob Petyo's Avatar
Rob Petyo
if it's the front one, i feel your pain it will fit
i did the same thing
Old Sep 23, 2008 | 09:48 PM
T.J.'s Avatar
T.J.
bump for a pic
Old Sep 23, 2008 | 10:06 PM
jedblanks's Avatar
jedblanks
one of them has to turn around, or three of them turn around, can't remember, but they don't all face the same way like they do when bolted to valve covers. Can't get to my car right now, but I had the same problem.
Old Sep 24, 2008 | 08:35 PM
molson's Avatar
molson
1 on each side must be flipped around.
Old Sep 25, 2008 | 09:18 PM
T.J.'s Avatar
T.J.
I flipped the one and it works, but now the holes have no threads. Can I place my tap into a drill? I was trying it by hand, but the hand tool keeps turning and not grabbing the tap.
Old Sep 28, 2008 | 10:14 AM
molson's Avatar
molson
Yup ...It can be used in a drill.Just go slow or you will break the tap.
To Pics needed: 97 coil pack on ZO6 bracket
