I just got coilovers put on my 2002 coupe.I got them from west coast corvette which are the exact same model as breathless performance.The ride is so soft the car almost floats.The car feels Extremely SPONGY, I guess thats the best way to describe it.The car feels way to soft and the tires rub when I pull out of my driveway.Yes the car is on the ground, but the tires shouldnt be jammed way up in the fenders going 2 mph.The car doesnt feel anywhere near as tight as it did stock.West Coast has got a call into the manufacturer.Has anyone else run into this problem with the breathless set up.I feel like Im in a damn caddy. :confused:
May I ask why you would spend so much $$ for that setup when you can pull 1g of handling with some good sway bars and bilstein shocks for under $1000 installed? :confused:
I've got the BPP setup. My car doesn't feel spongy. The ride is much smoother than the Z51 that was on there, but I believe that is because of the elimination of the crosstalk between axles. The handling is definitely improved. Sticks better, corners better, feels safer. My car isn't as low as yours though. I'm at 26 1/4 front and 26 3/4 rear. I have a little bit wider tires than stock too. Eric
Perhaps you got a set of softer springs for your coilovers? I imagine there are many different available springs for different applications. Springs designed for dragracing would be a much softer spring to promote weight transfer to the rear of the car upon launch.
I really like the idea of coilovers but I would want to be able to change to a bunch of different stiftness of springs without tons of labor involved. These reasons are why I think more and more that I am going to go with a set of HAL adjustable shocks. I want to be able to quickly swtich between dragrace, autox and roadrace mode with my car.
OLIVERm5,
I'm curious. I have the Z51 package. Will the the Bilstein Shocks alone (without lowering) increase the handling closer to 1G? I thought the tires had a lot to do with that (I'm thinking of the S03's)? How much closer to 1g will I get If I lower the car 1"?
Ha-Ha - get the bilstein shocks, either Hotchkis or T-1 sway bars, and a set of good rubber (I prefer michelin pilot sports) and you will never need more than that. I have the T-1's and run winding roads at 120 mph with confidence. Don't forget the Z06 alignment as well..........
Thanks Oliver. This is a confusing topic though. I just spoke with BPP about lowering. He suggested Coil Overs!!! $1500??? S h i t, all I want to do is just lower the damn car, 1" in front 1.25 in rear, and not suffer too much ride quality - if gotta get the Bilsteins then that's fine. If I gotta allign the car to prevent wear then thats fine too!!! I've been in VSTELLA'S car, who has the Bilsteins, and it wasn't that bad.
S h i t, I had one guy tell me that lowering will cause springs to rub up against your oil pan if its not done right!!! He wanted to charge $300! But I guess if you ask to many people, you get too many different answers.
[Modified by Ha-Ha, 4:10 PM 1/7/2002]
Not likely. Skidpad numbers are steady state, on smooth pavement. As with anything having to do with the suspension, there is no easy answer. But skidpad has less to do with shocks than almost any other aspect of the handling. Shocks will have a large effect on real world handling, and slalom runs though.
To improve skidpad, the most important changes would be tires, sway bars, spring rates, and camber settings (I think camber, I always confuse it with caster).
I got the coil overs ... don't feel nothing like what you describe... and these are the set from WCC, on my freakin' Z06! .... you better check your springs dude ! :D:D
Re: COIL OVERS WAY TO SOFT (Ha-Ha)
Mark,
My car sits at 26 5/8 front and 27 rear, which is about what you are talking about lowering your car. I have the Bilsteins with no problems and the car looks and handles better.
My car with the Z06 springs and swaybars, Bilstein sport shocks, Z06 alignment along with the S03's is a combo that is tough to beat in the real world. Any car can be made to push serious G's but it has to be driveable, meaning if there is a bump at the apex of a corner is your car going to absorb it and hold the line or skitter off into the rhubarb? My CD player stops playing when I jam it into corners :eek: and I can't even drive that well............
Hell ya Im havn them checked.I wish you lived in my area so you could drive it and see.I have 2 friends drive it who own vipers and a ferrari 348 and they both agree that its very sponge like.Im hoping all it is, the manufaturer sent the drag springs by mistake? Im crossing my fingers, one thing I do know is craig at wcc will take care of it
From: Buy USA products! Check the label! Employ Americans
Re: COIL OVERS WAY TO SOFT (vettethret)
I had the good fortune to finally ride in a car with coil overs. They were far from soft. The car seemed to handle great. I don't know how much better than my setup but I will see at the track this year. But the were purcahsed from a tuner with much roadrace experience. That seems to make the difference when I purchase things. Yea maybe a few bucks more but the real skinny and the proper advice latter. Lw may look cool but if you want to handle you ca go to low.
Bliss,
Do you know what spring rates you have on your coil overs.The manufacturer is sending out new springs. They said they are going to be 550 lbs in the front and 350 lbs in the rear. Let me know what your spring rates are when you get a chance.
It's all about personal opinions about what is soft(spongy ?) and what is concidered hard. What matters is your personal taste and the spring rate to match. As Matt wrote earlier in this post the spring rate and the shock valving differs if you want to have the car setup for street, dragracing or roadracing(autoXing). Find a spring rate you like and tell the vendor how you will be using the car to get a matching valving of the shocks. To make it even more complicated the shock valving must match the spring rate. The next step of course is coilovers with adjustable shocks but it's high $$.
OliverM5,
It's a huge difference between the stock leaf spring setup and coilovers. With coilovers you get four completely independent corners that follows the road perfectly. Cornering at high speeds on rough surfaces is a dream with coilovers, no more sidestepping causing you to almost, or even loose the control of the car.
Seanr,
I understand that it is a matter of personal opinion but your car has either a firm ride or it doesnt.I am asking about the spring rates because I would like to see what people are running on the streets and do some comparison and see where I should go from there.There is something definetly wrong with the set up now.It feels like an amc gremlin with 200k miles on it.Since you do have the coilovers what is your spring rate.I also noticed that you chhged them out for ohlins.Do you mostly drive the car on the track? mine is purlety street. The answers to these questions would be appreciated so I can figure out how to solve my problems. :cheers:
vettethret,
I can not answer the spring rate question now, I have to check it out so it will take a day before I post. And yes, my car is mainly used on the track but I use it alot on the street as well but track performance has priority.
I did not change the spring rate when I changed my DRM Bilstein coilovers to Ohlins. The main reason to use the Ohlins is that they are concidered to the the best racecar shock available and of course they are 20 point adjustable.
