Help on multi-function switch
Old Sep 24, 2008 | 03:18 PM
goatjacket's Avatar
goatjacket
Default Help on multi-function switch
Posted a request in the for sale section for a used manual to help but...
I need to replace my switch in an 02 Z06 and have no idea how to do it. part alone was over 300 bucks through the dealer but thankfully Gene was able to get it cheaper at the warehouse (thanks a ton!). Now i just need to figure out to do the swap. I've never pulled a steering wheel or airbag before so i am a bit anxious about this install. Any do-it-yourselfers have a write up for me on this one? Kind of a pain in the rear for a simple tail light/parking light problem!
Sorry if this post is in the wrong place...tech seemed the best spot to ask.
Old Sep 24, 2008 | 03:23 PM
c5streak's Avatar
c5streak
Here's a pictorial with all you need. Thanks to Alaskanpilot for the info.
And you don't have to remove the wheel or the airbag!
http://forums.corvetteforum.com/show....php?t=2032925
Old Sep 24, 2008 | 06:37 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
If you need any clarification on anything in that writeup, shoot me a PM!
Old Sep 24, 2008 | 07:32 PM
goatjacket's Avatar
goatjacket
Excellent write up indeed, thank you!
PM sent to you simply for a troubleshooting consult
Old Sep 25, 2008 | 02:05 PM
gpracer1's Avatar
gpracer1
I had headlight/tail light problems too and found the writeup on fixing the switch for No $.
Works great for 2 hours of work and no money spent.
Old Sep 25, 2008 | 04:55 PM
BostonVette's Avatar
BostonVette
Default Fixed it instead
I did the fix also...
Definately worth the time
Old Sep 25, 2008 | 11:38 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I replaced mine and the steering wheel removal wasn't necesary. This was on a '99.
To Help on multi-function switch
