Pop and Smoke in Dash
If you just had the stereo installed you may have a hot wire exposed somewhere.
Just my guess.
Just my guess.
http://forums.corvetteforum.com/show....php?t=1561772
EDIT - And these threads -
http://forums.corvetteforum.com/show....php?t=1921847
http://forums.corvetteforum.com/show....php?t=1862114
No codes,but driver side is 10 degrees warmer than passenger side. My guess is the actautor. Do I need to remove the dashpad to get to driver side actuator?
Going to check behind the stereo tonight for any shorts.
You have an aftermarket stereo, so you MAY have already removed the Bose module above the gas pedal. If not, then it's just two small machine screws to take it out. (7mm I think.)
Once that is removed, lie on your back and slide your head up under the dash area. Look up towards the ignition switch and temperature sensor. See the black tube running up to the dash? It's about the size of your thumb... it's easily pushed out of the way or disconnected to get your hand up in there.
Now look up and towards the center of the dash. There is the actuator, held in place by two screws. (7mm or maybe 5mm?) Remove the electrical connection and two screws and it pulls right off.
Piece of cake.
An easy way to check to see if it works: With the car running and AC on, turn the temperature control **** to full cold deck. (60 degrees) The actuator should move to full stop. Then rotate it to full hot deck. The actuator should move to the other full stop. If you get full motion, your actuator is fine. If you don't, or if you hear any grinding, it's toast.
A 10 degree temperature differential could be a low charge.
Hope this helps.
Mark
Piece of cake.
Hope this helps.
Mark
John
but probably 15 seconds or so. Never thought about practicing this before.
John
Going to put evrything back together. The only thing I noticed is that when I try to adjust the passenger side temp up or down with the right side controls, nothing changes. Any ideas why the passenger side will not change? There are no codes at all. Thanks.
