Shift Indicator stuck in first
Old Sep 26, 2008 | 05:09 PM
sjbrothers's Avatar
sjbrothers
Default Shift Indicator stuck in first
Another problem I had with my 98 vett was the shift indicator was in the dark and stuck in first (automatic transmission). I wanted to change the light and and the only way to get there was to remove the panel around the shift lever. I took the console and instrument panel off to change the bulb and found the indicator was broken and the plastic piece that surrounded the bulb was melted. I took the assembly apart and using a 1/2 inch drill, I refreshed the area around the bulb. I then used epoxy to repair the orange shift indicator. I used a small piece form a clorox bottle as a splint on the shifter indicator to help beef it up.
Here are the parts I am talking about fixing
I enlarged this area to give clearance with the bulb. This bulb is "on" with the ignition on and apparently caused the plastic to melt.
Final assemmbly
The picture shows the shift indicator before assembly. It takes a little effort to disassemble and reassemble but it can be done. Now the question is how long will it last? Anyway I have more epoxy!
Old Sep 8, 2009 | 06:13 AM
02603sec's Avatar
02603sec
Default nice post
mine was broken too. Took it apart and couldn't find the piece that broke off. searching for the replacement needle is fruitless and time consuming. I took it out, now there is no confusion as to which gear I'm in.
Old Sep 8, 2009 | 11:26 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Nice work.
Old Oct 23, 2009 | 02:45 PM
02603sec's Avatar
02603sec
Default about the shift needle--
I called my local corvette parts supplier- contemporarycorvette.com they had a needle for me. I installed it in 10 mins. These are RARE people that go beyond the extra mile to help. They once sold me a vette l98 for my iroc that didn't work out and replaced it. their ebay store is Fparts. NJ emissions wouldn't pass me without the shift needle. It's an attention getter, they see this beauty come in and 4 guys jump all over it, under the dash, opening the hood, hooking up to the ecm. Foreign cars just go right through.. your tax dollars at work.
Old Oct 23, 2009 | 09:22 PM
bobc997615's Avatar
bobc997615
If you make sure that the needles slides easily on the guide, it should last for quite a while. The big thing is to carefully assemble the indictor/shift assembly to the console as to not break the needle again. It is kind of a engage the indicator in a down motion, slide the asm to the left, then to the fully down position.
I broke my needle trying to replace the light and had to fully disassemble the shifter assembly to fix it.
Old Oct 24, 2009 | 01:42 AM
Padrino's Avatar
Padrino
My fix is a bit different.
I'm replacing the boot and shift indicator, et al with a stainless plate from a vendor on this forum, covering the shift rod with a stainless tube and toping the whole thing with a C2 Muncie T-Handle shifter and ball. Bit of work but won't have to worry about breaking that 99 cent red tabl...plus I'll get rid of this boring stock shifter setup
Padrino
Old Apr 10, 2012 | 12:00 AM
sirlawrence's Avatar
sirlawrence
Cruising
Help! How do I take this apart to get at the shift indicator and bulb please? Thanks to all!
Old Apr 14, 2012 | 08:33 PM
sirlawrence
Cruising
I don't want to force or break anything to get at the shifter .
Old May 13, 2014 | 02:53 PM
jimcork1's Avatar
jimcork1
Has anyone found a replacement part for the plastic indicator?
To Shift Indicator stuck in first
