do i have z-51 susp.??
Old Sep 27, 2008 | 03:47 AM
slvrC5vert's Avatar
slvrC5vert
Default do i have z-51 susp.??
i have a 2000 convertable, a4, with 3.15 gears, and HUD. is there any way to tell what suspension i have without ordering the build sheet?
Old Sep 27, 2008 | 05:51 AM
Grayeagle's Avatar
Grayeagle
VIN number check with a GM rep ..will tell you everything about the car
-Frank
Old Sep 27, 2008 | 08:37 AM
toolguy66's Avatar
toolguy66
The sticker that's in your glovebox has all the info for that car, look at it and see if there is Z51, if it says it you have it.
Mark
Old Sep 27, 2008 | 08:40 AM
slvrC5vert's Avatar
slvrC5vert
thanks guys
Old Sep 27, 2008 | 08:42 AM
slvrC5vert's Avatar
slvrC5vert
and if u dont mind, can u explain the difference between regular and z51 susp. ?
Old Sep 27, 2008 | 08:48 AM
JEEP/C5's Avatar
JEEP/C5
Power steering cooler, firmer springs and shocks, larger sway bars front and rear, lower gearing.
Old Sep 27, 2008 | 09:32 AM
itzza427's Avatar
itzza427
And the rear sway bar is supposed to have metal end links(mine does) instead of plastic links.(not sure about the front links,,I've heard different opinions there,,and haven't looked for myself yet)
Old Sep 27, 2008 | 09:42 AM
slvrC5vert's Avatar
slvrC5vert
ok, thanks. i checked in my glove box, and i dont have the z51 susp. but i do have 3.15 gears thats good enough for me....thanks again
Old Sep 27, 2008 | 10:16 AM
itzza427's Avatar
itzza427
I'm not an expert on A4s,,but someone posted just the other day that 3:15s were part of the Z51 package for the A4s!!
Old Sep 27, 2008 | 10:46 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
10 seconds, pop the hood, fins on the p/steering line near the rack?? yes? Z51
Old Sep 27, 2008 | 10:47 AM
Secret237's Avatar
Secret237
Mark
Mine is a 99 A4 and it has 3:15 and it is NOT a Z51, also a 2000 should have metal sway bar end links.
Here are my RPO codes (from sticker inside glove box)
FE1 Base Suspension (Upgraded to FE4 2-2007)
F45 Selective Real Time Damping
G90 Axle, Rear, 3.15 Ratio
G92 Performance Axle Ratio 3.15:1 MXO Auto
It's not going to say "Z51" on the sticker in the glove box, it's going to read "FE3" to indicate the Z51 package. You can also tell by the diameter of your sway bars as follows:
Swaybars
23mm, front; 19.1mm, rear --- FE1/Base ( my old bars )
25.4mm, front; 21.7mm, rear --- FE3/Z51 97-99
28.6mm, front; 23.6mm, rear --- FE3/Z51 00-04
30.0mm, front; 23.6mm, rear --- FE4/Z06 ( my new bars as of 2-17-07 )
31.75mm, front; 25.4mm, rear --- Hotchkis
38.4mm, front; 27.5mm, rear --- GM T1
Note that if you have an older '97-'99 C5 with plastic swaybar endlinks, you will need to go to the GM aluminum endlinks for the larger bars (GM PN:10435298, ~$60/set), as the old-style plastic ones can snap with the force from the stronger bars. Fichtner includes these in a Z06 bar order, along with the new rubber bushings for the
larger bars.
Old Sep 27, 2008 | 10:52 AM
Shore's Avatar
Shore
My 97 has a Z51 RPO code on the storage lid in the rear.
Old Sep 27, 2008 | 11:21 AM
SteveDoten's Avatar
SteveDoten
correct, along w/ the 98's, 99 rpo's started in the glove box
To do i have z-51 susp.??
