*&^%$ windows
Old Sep 27, 2008 | 04:47 PM
mardereoj's Avatar
mardereoj
4th Gear
Default *&^%$ windows
HELP FRIENDS at first the left window quit then it started working again .now both windows wont work memory wont work or pwr mirrors, or left pwr door lock . right pwr door lock works fine HELP PLEASE
Old Sep 27, 2008 | 05:28 PM
MY2002NA558HPZ06's Avatar
MY2002NA558HPZ06
Cruising
check fuse?
Old Sep 27, 2008 | 06:38 PM
NavyDoc2007's Avatar
NavyDoc2007
Grab the rubber accordian tube that contains the wiring harness the goes to the door and shake it while pushing the window switch.
Here's a link with pictures:http://forums.corvetteforum.com/show...ight=accordian
Old Sep 27, 2008 | 07:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
My first thought too.. from Bill Curlee's find.
Old Sep 27, 2008 | 08:50 PM
mardereoj's Avatar
mardereoj
4th Gear
Default windows
Thanks but i tried that, how do you remove the switches panel.
Old Sep 27, 2008 | 09:26 PM
lionelhutz's Avatar
lionelhutz
Any error codes?
Does the right window work from the right door controls?
Sounds like it could be in the serial communications link?
Peter
Old Sep 27, 2008 | 10:25 PM
mardereoj's Avatar
mardereoj
4th Gear
Default windows
Peter, no the only thing that works is the right door lock from the right switch. do you know the fix for what you are talking about?
Old Sep 27, 2008 | 10:40 PM
mardereoj's Avatar
mardereoj
4th Gear
Peter only the righy door lock works with right lock switch got any sugestions?
To *&^%$ windows
