Idle Vacuum
Old Sep 27, 2008 | 07:40 PM
SCannon's Avatar
SCannon
Default Idle Vacuum
I have a 402 with a 242/250 600 lift cam, AFR 225's 11:1 Compression. At 1000 rpm idle im pulling 7 inches of vacuum. Is that too low?
Old Oct 13, 2008 | 12:18 AM
SCannon's Avatar
SCannon
Bump, anyone?
Old Oct 13, 2008 | 08:19 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Too low considering your setup? Possibly. I had a little bit smaller duration cam and was pulling around 12" vacuum. Just make sure you don't have any vacuum leaks. You might be able to play with the idle timing and fueling to gain an inch or two of vacuum.
Old Oct 14, 2008 | 08:38 PM
SCannon's Avatar
SCannon
I pulled 544 rwhp N/A so its a fairly stout engine..
To Idle Vacuum
