active handling with new tires
Old Sep 28, 2008 | 06:57 PM
matt3310's Avatar
matt3310
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
2016 C7 of the Year Finalist
2015 C6 of the Year Finalist
Cruise-In X Veteran
St. Jude Donor '09 thru '19
Default active handling with new tires
I just got new rear tires put on. There the original size. After a short drive, my AH came on then went off. It did this about 4 times in about a mile. I live only a mile and a half from work, so no real miles put on it yet. What has caused this?
Thanks,
Matt
Old Sep 28, 2008 | 07:11 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure what you mean the AH came on and then went off. Was it an Active Handling Active message, Traction Control Active message, or did you get a Service AH or Traction Control message?
You need to be specific in your terms and state exactly what happened and what was shown on the DIC.
It would be a very unusual case if Active handling was triggered by the tires but Traction Control is often triggered by tire issues.
Bill
Old Sep 28, 2008 | 11:07 PM
Bluefire's Avatar
Bluefire
The new tires are probably just a coincidence (assuming you replaced them with a compatable size). My car started throwing Active Handling Acitve messages in the DIC. It turned out to be the Steering Wheel Position Sensor went bad. This failure seems fairly common in the C5 section. When this happens, do you feel the break pedal pulsate VERY fast (faster than ABS engagement)?
In case you ask later, the sensor is ~$80 and the labor was ~$240.
Old Sep 29, 2008 | 01:06 AM
matt3310's Avatar
matt3310
Cruise-In X Veteran
the dic showed "active handling active". when this came on it felt like the car lost power. very much like when the brakes came on briefly.
Old Sep 29, 2008 | 02:26 AM
Bluefire's Avatar
Bluefire
It was braking then, that is how it works. When AH engages it alternates applying the front brakes very rapidly. The system may also disable the AH and TCS when it happens. Whenever it happened to my car it would post codes C1287 and C1288.
Good Luck, Feel free to PM me too.
Old Sep 29, 2008 | 08:19 AM
FRCTony's Avatar
FRCTony
Could be mold release on the new tires.
Old Sep 29, 2008 | 08:23 AM
lucky131969's Avatar
lucky131969
Could you elaborate?
Old Sep 29, 2008 | 10:19 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I think he's talking about the gooey compound to keep the tires from sticking in their molds possibly causing the tires to not stick to the pavement. For the record, I don't agree.
To active handling with new tires
