Simple brake caliper question. Fronts.
Old Oct 2, 2008 | 08:19 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Simple brake caliper question. Fronts.
Is the bleeder valve located at the top or bottom of the caliper? I just put a C5 front brake kit on my Z and I think I am azz-backwards.
Thanks. Also, can one get Speed bleeders at any parts store or is it an online order thing like Zaino?
Old Oct 2, 2008 | 08:52 AM
2GOFAST's Avatar
2GOFAST
Bleeders are on top - otherwise how would the air escape.
Old Oct 2, 2008 | 10:07 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
You will probably have to order them on line. I tried the local auto parts stores and speed shops and none had the correct size in stock. The speed shops said that they could order them but it was just as quick to order them on line.
Old Oct 3, 2008 | 03:53 PM
Oldvetter's Avatar
Oldvetter
Sears sells a non-craftsman vacuum brake bleeder for $34, it works fine with standard bleeders, no fuss no mess. Extract 2-3 ounces on each brake, use turkey baster to suck out old fliud from master cylinder (not too low) and replace first. Then keep adding after bleeding.
To Simple brake caliper question. Fronts.
