How do you dyno an A4?
Old Jan 8, 2002 | 07:44 PM
FarmerBob2001's Avatar
FarmerBob2001
Default How do you dyno an A4?
People say to dyno the M6 in a certain gear (4th I think), but what do you do with an A4?
Won't the trans kick-down when you floor it? And if you don't floor it to prevent the kick-down, won't you get lower numbers?
I think I read in the manual that if you start in 2nd from a stop, the trans will start (and stay) in 2nd. Is that the gear to use with an A4?
Old Jan 8, 2002 | 09:55 PM
sternvette's Avatar
sternvette
Default Re: How do you dyno an A4? (FarmerBob2001)
Buckmaster is right. An A4 is usually done in 3rd gear. Everytime i've seen it done it has been!!
Old Jan 8, 2002 | 10:14 PM
1HOTVETT's Avatar
1HOTVETT
Default Re: How do you dyno an A4? (VNAMVET)
when I dynoed I used third gear and where the MN6 is floored @ about 2500rpm, I had to wait till about 2700-2800rpm then just :smash: it
Old Jan 8, 2002 | 10:22 PM
vstella's Avatar
vstella
Default Re: How do you dyno an A4? (1HOTVETT)
Most A4' with 3:15 gears or higher are tested in 3rd from 65mph-150 mph.When I had the 2.73's I tested in 2nd from 80mph-120mph.Each
Dyno operator has their routine.They will guide you through it.
Bring earplugs:D
Old Jan 8, 2002 | 10:59 PM
FarmerBob2001
Default Re: How do you dyno an A4? (vstella)
Guess I should have mentioned I have the 3.15s...
I hope to dyno it, add an intake, and dyno again. I'm just not sure if it's worth the cost, since the intake will only be around $250.
Old Jan 9, 2002 | 12:46 AM
CliffB-99's Avatar
CliffB-99
You should make sure you drive your car pretty hard at least 50 miles after installing the intake before you dyno again. Computer needs to relearn the added air flow.
Old Jan 9, 2002 | 12:49 AM
jimhild's Avatar
jimhild
We did ours with Breathless Performance at the Birthday Bash. Used 3rd gear to rev. limiter, about 150 mph with the 3.15 axle ratio. The operator will tell you how he wants to run the tests.
Good Luck!
:cool:
Old Jan 9, 2002 | 12:54 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: How do you dyno an A4? (CliffB-99)
the key factor is puttin the transmission in the 1:1 gear.....in the A4 it is 3 and in the M6 it is 4
I have driven both on the dyno, gotta go about 70ish in the A4 then floor it ....in the m6, just mash the gas at 40 MPH
hope that helps
Old Jan 9, 2002 | 08:14 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Re: How do you dyno an A4? (Ram Air Tony)
I race in 3rd..................should Dyno in 3rd.............
We will have our local dyno day on the 19th! :D :D, we will see :yesnod:
Old Jan 9, 2002 | 01:43 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: How do you dyno an A4? (ALLTHROTTLE&NOBOTTLE)
If I remember correctly, I did 2nd once (by mistake) and the hp came out much lower. Next run, operator told me to keep it down till it shifts to 3rd and then go to redline. So 3rd is the proper gear.
George
To How do you dyno an A4?
