Z06 spark plug question
Old Jan 9, 2002 | 12:23 AM
MJM's Avatar
MJM
Default Z06 spark plug question
Putting in new set of plugs while dealership is doing ring job on my 2001 Z06 (cringe!).
I couldn't find any part number or gapping information in my shop manual. I know the dealership should be able to look this up, but they screwed up my alignment so I learned to double check.
Thanks, and where exactly does one find this information?
Old Jan 9, 2002 | 01:08 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Z06 spark plug question (MJM)
Hello Z06 section :p:
(you might want to post this there-- since it's dedicated to the z)
:cheers:
Old Jan 9, 2002 | 08:27 AM
MJM's Avatar
MJM
Default Re: Z06 spark plug question (MDL-01C5)
:cheers:
This is the tech section correct?
Old Jan 9, 2002 | 09:31 AM
Ranger's Avatar
Ranger
Terrific how-to on changing spark plugs is on Kewlbrz's web site. It covers all the specs including gap and torque specs. Here is a link.
http://www.vetteguru.com/mods/ignition/
It might even encourage you to change your own plugs. :)
Ranger
Old Jan 9, 2002 | 12:51 PM
MJM's Avatar
MJM
Default Re: Z06 spark plug question (Ranger)
Ranger
Thanks for the info, I normally do all my own work (pads, rotors, fluid changes) but I figured since it was at the dealership already and the heads were off, I might as well swing by with a new set of plugs and swap em out.
This will probably be the quickest spark plug change ever! Not too hard when its out of the car and laying on a shelf.
Old Jan 9, 2002 | 01:03 PM
Ranger's Avatar
Ranger
That ought to make it easy to change even that pesky #7 plug.
Ranger
To Z06 spark plug question
