Key FOB question
Old Jan 9, 2002 | 03:42 AM
Rovent's Avatar
Rovent
Default Key FOB question
I had a problem with mine. I put a new battery in it but it seems to lose it's memory about once a day. If I reprogram it, it's good for a while. Any ideas?
Old Jan 9, 2002 | 09:01 AM
Tom/99's Avatar
Tom/99
Default Re: Key FOB question (Rovent)
Sounds like replacement time. Is it still under warranty?
Old Jan 9, 2002 | 05:06 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
If the battery is good, you might need a new one. However you could take a soldering iron and heat up the connection joints on the circuit board. You might have a cold solder joint or the circuit board could have a hair line crack.
To Key FOB question
