Spark plug replacement after 10 years...
Any ppl here replaced 10 years old plugs on a c5 ?....Im going to pay a corvette shop here to do it...or should i leave the old ones in till about 50k miles?....car drives like a dream...if it aint broken should i fix it?...your ideeas please!
If the car is running fine just leave it. You can go way past 50k miles without any issues.
The plugs and wires are not such a bad job to replace.
Again, if the engine isn't misfiring, the plugs are fine.
HTH, and have a good one,
Mike
.If you do it yourself, please wear gloves so you don't cut & scrape your hands.
My recommendation is the Delco Iridium plugs and the GMPP red wires.
If you do a search on here for "spark plug replacement", you will find plenty of help.
Just because the platinum and iridium plugs can go 100K without issue doesn't mean that they shouldn't ever be removed and checked.
I would pull the plugs and wires and inspect them. If everyhting looks fine put them back in. Apply anti sieze to the plug threads and make it a routine maintenance item to pull andcheck them at least once a year.
Although not in this engine, I've had plugs break off due to corrosion when I've tried to take them out. Not pretty.
Doing them yourself will be a bonding experience with your car and may be less expensive. It gives you DIY confidence. You will however, not have an enjoyable time doing them. You may need to buy some new tools (that where it usually gets more expensive)...but, I like to buy new tools.
The fact that the plugs are the original plugs and in aluminum heads could be an area of concern. You certainly don't want to strip the threads. Use care yourself or have them done professionally. Use anti seize and you're good for another ten years...
http://forums.corvetteforum.com/show....php?t=2151603
Finally, a voice of reason.....
The PCM only uses two sensors to modify the ignition and pulse width commands: the knock sensor and the O2 sensors. The computer only pulls timing when knock is detected, and modifies the fuel trims in real time to maintain the O2 set point (which can change depending on throttle request).
What else would it use? As far as power gains with brand new plugs goes, sure, you'll see it, for about a month. Go back to that dyno (if you really care) after 2-3 tanks of gas and see what happens to that gain. It'll be back where it was (within the noise of the dyno measurement).
Plug gaps from the factory are .053. 60 thou is fine, 80 is opening up some. BUT, if the engine isn't misfiring, the plugs are running fine.
To the OP, the factory plugs are still going to come out tight, so be careful (and patient) when you pull them. As others have mentioned, soak them the night before with some penetrating oil, and make sure the engine is STONE COLD. You want to give yourself every opportunity to have them come out easily.
Then, when you put them back in, put a small amount of antisieze on the plug threads.
Mike
After almost 2 years since my original post and another 10M I have finally changed my plugs and wires... 12 years and 44M on originals.
Installed AC Delco Iridiums gapped at .40 and MSD wires.
wow! Fells like I gained about 10 hp and is soooooo smooth. Simultaneously got 2 brand new K&N cone air filters for my dual intake.
If GM says that plugs are good for 100M don`t know what to believe because mine weren`t...or maybe just the wires were bad?
Visually both plugs and wires looked great...but were not running properly
However, after a tank or 2 I've noticed consistently that the car is running back to normal.
Keep a critical eye on the longer term results; it's real easy to get in the mindset that "I did something, it MUST be better."
The good thing that swapping the plugs out after 12 years is you broke the threads loose (I bet some of them squeaked coming apart) before damaging the threads. You should have put a small amount of antisieze on the threads.
Finally, man, drive your car more! 10k miles in 2 years?? C'mon, your baby is begging "let's GO somewhere!" (yes, I have conversations with my rides
)Have a good one,
Mike
The shop manual says to put a drop of engine oil on the threads, so I doubt that anti-seize was ever applied at the factory.
I know a politician who must live by that creed...
