Water dripping inside car
Old Oct 8, 2008 | 04:05 PM
gja's Avatar
gja
Default Water dripping inside car
I have an 04 coupe. Unfortunately I had to leave it outside during some heavy rainfall. As soon as I drive away and turn right, some water drips onto my left foot and ankle.
Any ideas how the water could be finding its way inside?
Old Oct 8, 2008 | 04:11 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Check the udders under the fire wall in the engine compartment I suspect the one on the drivers side is pluged up with debris
Old Oct 8, 2008 | 05:02 PM
gja's Avatar
gja
Do I get to the udder by crawling under the car? Or can I open the hood and reach down?
Old Oct 8, 2008 | 09:25 PM
87bob's Avatar
87bob
The ones on the driver side is under the wiper motor here is a photo of ones that are clogged. http://forums.corvetteforum.com/show...ghlight=udders
I'll try to find a good photo of the one on the passenger side and do a second post Here is a good picture of the one on the passenger side see post 65. http://forums.corvetteforum.com/show...=udders&page=4 Hope this helps if not do a search on water leaks there is some good info out there.
Old Oct 8, 2008 | 11:20 PM
gja's Avatar
gja
Found the ones on the drivers side. Real easy. I'm gonna wait for the next rainfall to see if that worked, before I try to get to the passenger side one.
Thanks for the info!
Old Oct 9, 2008 | 10:05 AM
87bob's Avatar
87bob
When you run the AC you should get condensate out of the the passenger side. When you wash the car I believe it will run out of the drivers side.
Old Oct 9, 2008 | 10:30 AM
gja's Avatar
gja
Actually, when I run the AC, I can hear the condensation sizzle as it drips onto the headers. So I'm ok on that side.
Thanks again.
To Water dripping inside car
