WTF, sucking slurping sound
Old Oct 8, 2008 | 09:14 PM
yaknow's Avatar
yaknow
Default WTF, sucking slurping sound
Replaced my intake manifold and installed a vararam at the same time, now I am getting a sucking sound slurping sound, anybody got any ideas? Sounds like it may be comming of the manifold area but not quite sure. My check engine light is on not quite sure how to check codes.
Old Oct 8, 2008 | 09:18 PM
fst85vtt's Avatar
fst85vtt
check the coupler on the mass air
Old Oct 8, 2008 | 09:39 PM
BADMFR's Avatar
BADMFR
St. Jude Donor '08
Usually a good thing.
Old Oct 8, 2008 | 09:46 PM
4DRUSH's Avatar
4DRUSH
Whats the problem
(except you should probably do the job again)
Old Oct 8, 2008 | 09:48 PM
RoccoC5's Avatar
RoccoC5
To check codes, with the engine running, hold the "Options" button on the DIC and press the "Fuel" button four times. It will cycle through the codes. Anything suffixed with an "H" means it's a historic code and not currently set. The codes ending with a "C" are current codes.
HERE's a good doc explaining the codes and how to interpret them.
Did you make sure to reconnect the hose from the brake booster to the back of the manifold?
Post back with your findings.
Old Oct 8, 2008 | 10:18 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
You should read codes with the key in the "on" position but not with the engine running.
Nice write up.
Old Oct 8, 2008 | 10:49 PM
RoccoC5's Avatar
RoccoC5
Nice write up.
You are right, thanks for correcting me!
Old Oct 8, 2008 | 11:08 PM
Blue 92's Avatar
Blue 92
I cheated and just got my ODBII scanner today.
For some reason neither the Explorer or Grand Prix will display codes using the Corvette instructions.
Old Oct 8, 2008 | 11:21 PM
yaknow's Avatar
yaknow
Ok, tightened the mass air folw coupler, this seems to have done the trick checked the codes and got
10 pcm 2 codes
p0141 H C
p0410 H C
Should I reset and see if codes reappear?
Old Oct 9, 2008 | 01:50 AM
RoccoC5's Avatar
RoccoC5
10 pcm 2 codes
p0141 H C
p0410 H C
Well, since it is a current code it will likely reappear. But there is no harm done in resetting the codes.
As you probably know, the P0141 code indicates an Oxygen Sensor issue, which wouldn't seem to be related to the recent work done on your car. The P0410 code refers to the AIR System...I found this THREAD and this THREAD on other forums; maybe they will help or someone more knowledgable will chime in. From reading these posts is sounds like the codes are related...not sure if installing the manifold or Vararam could have anything to do with it, though.
Let us know how it goes!
Rocco
Old Oct 9, 2008 | 02:48 AM
lucky131969's Avatar
lucky131969
10 pcm 2 codes
p0141 H C
p0410 H C
Based on those codes, you need to go back over your work...specifically the security and connections in the AIR system. My guess is, you have left a hose loose from the AIR pump to driver side bank union.
Old Oct 9, 2008 | 10:21 PM
RoccoC5's Avatar
RoccoC5
One other thing you may check is whether the a/c is blowing out of the correct vents (i.e. floor when set to floor, front vents when sent to front vents, etc). If it's not working properly, the small hose that connects to the back of the manifold may be loose and could be throwing the P0410 code.
Old Oct 9, 2008 | 11:00 PM
02gt350's Avatar
02gt350
its probably the fact you have a good intake now and can hear the air rush in....its common on aftermarket intakes...its fine, and i think sounds pretty sweet
Old Oct 10, 2008 | 01:41 PM
Bluefire's Avatar
Bluefire
Assuming you did the job correctly. I noticed the same new "sucking" sound after I installed the VaraRam.
Old Oct 10, 2008 | 02:59 PM
HWY HNTR's Avatar
HWY HNTR
hahaha....
Old Oct 14, 2008 | 08:16 PM
yaknow's Avatar
yaknow
Thanks guys for all the info, took a 500 mile cruise this week-end after resetting DIC, got the P 0410 code after a couple of hundred miles of driving. Will re-tork manifold and see if it resolves the code issue.
Old Oct 14, 2008 | 08:24 PM
ZeeOSix's Avatar
ZeeOSix
Nice write up.
Actually, the DTC system will work either way. I read and reset codes "on the fly" sometimes. Try it sometime.
Old Oct 14, 2008 | 09:21 PM
lucky131969
Have you checked all the AIR connections?
To WTF, sucking slurping sound
