C5Z06 wheel alignment specs??
Old Oct 9, 2008 | 09:05 PM
Irish Whiskey's Avatar
Irish Whiskey
Default C5Z06 wheel alignment specs??
Anyone have the camber,caster,toe for the C5Z06?
thanks
Old Oct 10, 2008 | 08:50 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Here are some specs
Z06 Wheel Alignment Specifications
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe +0.14 to -0.06 degrees +0.04 degrees
Front Sum Toe +0.28 to -0.12 " +0.08 "
Front Individual Camber +0.50 to -0.70 " -0.20 "
Front Cross Camber +/- 0.25 " within 0.50 "
Front Individual Caster +6.4 to +7.4 " 6.9 "
Front Cross Caster +/- 0.25 " within 0.50 "
Steering Wheel Angle +1.0 to -1.0 " 0.00 "
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe +0.09 to -0.11 degrees -0.01 degrees
Rear Sum Toe +0.18 to -0.22 " -0.02 "
Rear Thrust Angle +0.10 to - 0.10 " 0.00 "
Rear Individual Camber +0.32 to -0.68 " -0.18 "
Rear Cross Camber -- within 0.50 "
Here are spec for all C5's
RPO Operation Service Preferred Tolerance Front Alignment Specifications
All Front Individual Toe + 0.04 +/- 0.10
All Front Sum Toe + 0.08 +/- 0.20
All Steering Wheel Angle 0.0 +/- 1.0
FE1 & FE3 Front Individual Caster + 7.4 +/- 0.5
FE1 & FE3 Front Cross Caster Within +/- 0.5 --
FE1 & FE3 Front Individual Camber - 0.20 +/- 0.5
FE1 & FE3 Front Cross Camber Within +/-0.5 --
FE4 (Z06) Front Individual Caster + 6.9 +/- 0.5
FE4 (Z06) Front Cross Caster Within +/- 0.5 --
FE4 (Z06) Front Individual Camber - 0.70 +/- 0.5
FE4 (Z06) Front Cross Camber Within +/- 0.5 --
Rear Alignment Specifications
All Rear Individual Toe - 0.01 +/- 0.10
All Rear Sum Toe - 0.02 +/- 0.20
All Rear Thrust Angle 0.0 +/- 0.10
FE1 & FE3 Rear Individual Camber - 0.18 +/- 0.5
FE1 & FE3 Rear Cross Camber Within +/- 0.5 --
FE4 (Z06) Rear Individual Camber - 0.68 +/- 0.5
FE4 (Z06) Rear Cross Camber Within +/- 0.5 --
