Why Mobil 1.
Have a good one,
Mike
Levi,
Royal Purple SAE 5w30 and SAE 10w30 motor oils exceed performance of API SJ, GM4718M and ECII Energy Conserving requirements.
Royal Purple motor oils are formulated with a degree of mineral base oils however they are primarily Group IV PAO (synthetic) based. You will not find a product on the market that is not formulated with a degree of Group III (mineral) or lower base oils (read the fine print on any bottle labeled 100% such as Mobil 1). Mineral base oils are used as diluent or carrier oils for solubility of the additive packages in the synthetic base stock as synthetic base oils in general possess poor additive solubility. As well, there are no industry standard definitions of full, blend, 100%, etc. and thanks to one major oil manufacturer what was once known as mineral base oil is now ( as ruled by the FTC) being legally referred to as "synthetic". Bottom line here, forget the labels, these are simply good/ better/ best marketing techniques developed by major oil manufacturers knowing the general public has no means by which to gauge high end oils (apparently our marketing dept. is guilty too). Thus consumers are directed into thinking a higher synthetic content automatically equates to greater protection/ performance. Unfortunately, it is not as simple as these marketing geniuses would have you believe, there is much more to the finished product than base oil. A well formulated mineral oil may very well outperform a poorly formulated synthetic.
Focus on performance. While synthetic base oils do offer significant benefits, additive technology plays the largest role in overall performance. Royal Purple does not simply rely on base oils for performance and/ or protection. The defining factor bwtween Royal Purple and other synthetics is our non-corrosive Synerlec high film strength additive technology. Synerlec is the foundation of Royal Purple automotive and industrial lubricants offering a film strength typically found to be 3 to 5 times that of other oils, regardless of base oil. This film strength equates to the benefits RP users repeatedly see simply due to less friction.
I have included the API specs/ certifications for Royal Purple SAE 5w30. For additional information the full product/ spec sheet can be viewed at http://www.royalpurple.com/pd/6.html.
Thank you for your interest,
Jared Martin
Royal Purple Ltd.
SAE GRADE SAE
Viscosity, cSt @ 40°C 62.5
cSt @ 100°C 10.5
Viscosity Index 160
Pour Point, °F -44
Flash Point, °F 395
Fire Point, °F 435
Total Base No.
(Detergent Alkalinity) 10.5
API Service Classification SJ/CH-4
GM 4718M
-----Original Message-----
Sent: Wednesday, January 09, 2002 10:15 PM
To: jaredm@royalpurple.com
Subject: Your 5W/30 Synthetic Oil?
Is your 5W30 synthetic motor oil 100% synthetic? I ask this because I am a 2000 Corvette Owner and we are mandated by our warranty to use Mobile 1 or an equivalent synthetic oil that meets or exceeds GM's specs. Your bottle does show that it meets the "starburst" specs that GM requires in our LS1 engines. Do you have proof that your motor oil is 100 % synthetic (your FAQ says it isn't, unless you get the racing RP) and that it does meet and/or exceed the Chevrolet Corvette LS1 engine requirements.
The '94 ranger has 100k plus with two teenagers operating it 50% of the time
and the engine is still quiet and has plenty of pep. The other issue of cost just
doesn't make sense. You can run longer between oil changes- as much as 3 times longer. So how is it more costly? I just bought 2000 coupe and the
dealer words to me were-" Change oil every 15000 or once a year and use only
m1-5w-30". He's been selling Vettes for 30 plus years. I'm 51 and old enough to remember when m1 came out and they boasted that it would "last" 25,000
miles between oil changes- But you won't see it anywhere now because they would sell less.
Regard, Tom :)
