Cant' do a Burnout?
Old Oct 11, 2008 | 10:47 AM
imbrbing's Avatar
imbrbing
Default Cant' do a Burnout?
Hi all,
This is my first post after being on this forum for a while, great info here!
I have an issue with my C5 2002. I can't do a burnout to save my life.
It runs GREAT on the highway and acts like it has plenty of power. But
from a standing stop no matter what I try I can't get the tires to smoke.
Is that normal for an automatic tranny. My car has an after market breather and is tuned with a SuperChips tuner. My best guesstimate for
horsepower is this
stock = 355
aftermarket breather = 5 more horsepower?
superchips tuned = 10 more horsepower?
total = 370 HP?
How can a 370 HP car not do a burnout?
After I did the superchips it does seem snappier so that seems to have added something
I turn off the traction system and have tried brake torqing.
What is up with my car? Normal?
Thanks all
Old Oct 11, 2008 | 10:57 AM
n8dogg's Avatar
n8dogg
if you are just mashing the throttle from a dead stop it wont smoke the tires. Turn your traction control off and hold down the brake and gas.
Old Oct 11, 2008 | 11:02 AM
BonestockZ06's Avatar
BonestockZ06
Don't forget to turn you TC off or else, you'll never be able to spin those tires. I'm surprised you bought a corvette without doing a burnout first. A burnout should have been part of your test drive. LOL
Old Oct 11, 2008 | 11:04 AM
imbrbing's Avatar
imbrbing
LOL, great point!
FYI I do turn the TC off when I try. I think I will try the "no mashing the peddle" trick while I brake torq it
Old Oct 11, 2008 | 11:13 AM
David426's Avatar
David426
FYI 350hp stock.. What gears? 2.73 or 3.15? I bet you have 2.73. Kinda hard to get much rubber off the line with this gear ratio.
Old Oct 11, 2008 | 11:48 AM
imbrbing's Avatar
imbrbing
Thats probably my problem then, the gear ratio. I will say though that the car at 70 MPH
feels like its starts to get into its groove and the "vette" legend starts to shine through.
It starts begging to be "driven" then, awesome cars they are huh?
I wish we had an autobahn here like in germany. Went to germany a month ago and was driving around the autobahn in a minivan doing 90(topped out, lol) while the whole time dreaming I wish I was in my vette
Thanks for the input guys, much appreciated.
Old Oct 11, 2008 | 01:15 PM
01_torch_red_vette's Avatar
01_torch_red_vette
go to an empty parking lot. crank the wheel all the way in either direction. put the gas pedal to the floor. let the tire destruction begin. serioulsy tho, you shouldnt be having trouble laying a patch in a straight line if you turn off the traction control and use light pressure on the brake. if you still have problems, and are determined to do burnouts, get yourself a brake line locker.
Old Oct 11, 2008 | 02:15 PM
gunnerrun's Avatar
gunnerrun
Default Tc
It may help to put it into competitive driving mode. 273 gears? Probably will not generate much smoke but should leave a couple of decent rubber patches.
Old Oct 11, 2008 | 03:01 PM
Mark-44's Avatar
Mark-44
Default Why do a burn out?
Tires are expensive.
But, burn outs before drag race can heat up "sticky" tires give much better traction and be much safer than street tires.
In all seriousness, my Arctic White 97 Coupe could not spin the tires when I first got it, but eventually it learned.
The 2:73's require gas on, brake-on torque; then off brake and smash the gas. It works for me; practice, practice, practice.
The video shows my 1997 basically stock coupe with the 2:73 doing a burn-out before a race. Keep trying and be safe.
Mark
Old Oct 11, 2008 | 04:20 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Mark
I miss something here? "Basically stock" with a 2.73 rearend? that runs a 12.4@110? and the other ran a 11.83@116? hmmmm
Old Oct 11, 2008 | 04:28 PM
Shore's Avatar
Shore
Basically stock my azz.
Old Oct 11, 2008 | 05:06 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Put it in neutral and rev it to 6k rpm and put it in drive.....
Kidding!
Corvettes hook very well, much better than Camaros... with my bolt on Zo6 it's still hard to loose traction unless (trying to burn some rubber) I give it some rpm before dumping the clutch.
You could always get a supercharger...
Old Oct 11, 2008 | 05:08 PM
vette dan's Avatar
vette dan
Vette Dan
Gear ratio and altitude.
Old Oct 11, 2008 | 06:09 PM
Mark-44's Avatar
Mark-44
The other one, Crosstheline's, is cammed with a 3:73 differential.....
The Arctic White '97 has only Bolt-ons (intake & exhaust) no internal engine work (ever) and does have the original 2:73 gear. On it's last trip to the track it ran 11.943 @ 114.3 MPH.
This debate has been covered extensively in this Forum's C5 Performance section and is listed in the "Official C-5 1/4-mile Times List".
Mark
Old Oct 11, 2008 | 06:40 PM
Shore's Avatar
Shore
Friggin WOW.
Shore's Avatar
Shore
List the intake and exhaust mods.
Old Oct 11, 2008 | 09:25 PM
Mark-44's Avatar
Mark-44
They are listed many times on the Forum...just click my avatar.
To Cant' do a Burnout?
Old Oct 11, 2008 | 09:43 PM
danielf's Avatar
danielf
Default Burn Practise...
Here are a few tips I learned as you progress forward...
# 1 If your doing street burn outs run the rear tire pressure up to 35lbs. {for practise only}
# 2 Get some water but not too much on the back tire to break them free !!!
# 3 learn to feather your brake pedal and your gas WATCH THE RPMS do not go pass 4000 rpm's til you get the hang of it
#4 I found the BEST way is to go to your local track ... Watch and ask questions ... the guys will be more than willing to teach you how to burn up your tires
Take care I hope this helps out and most of all keep cool and have fun
Old Oct 12, 2008 | 09:17 AM
Darrell G's Avatar
Darrell G
Gear ratio makes an amazing diff. I have driven two friends C5s with 2.73s. They were also disappointed in not being able to light up the tires. I had to really work at it, and even then, it was not much of a show. My basically stock C5 with 3.15s gets down right squirrelly w/TC turned off.
Old Oct 12, 2008 | 11:10 AM
David426's Avatar
David426
I noticed you live in Colorado,, What is the elevation?
