Oil Pan Drain plug bolt head stripped. Please Help
Old Oct 12, 2008 | 03:53 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Default Oil Pan Drain plug bolt head stripped. Please Help
Hey guys, it seems that I come to you all with thes dumbest things sumetimes, but I am stumped. I am so p*ssed right now.
Went out to change my oil this afternoon, and I got halfway through when I couldn't get the drain plug out. I noticed I was having some trouble with it, but I have never had this kind of trouble. Yes, I was using thr correct size socket - 15mm. I noticed it was starting to round off, so I changed my plan. I tried applying heat from a propane torch to the bolt and the pan itself, I tried tapping on both with a hammer while trying to turn, and just about everything else. The socket (6 point) completely reounded off the bolt head, so I switched to vise grips and they are actually moving the metal around.
I am at a loss for words. I have been changing oil in cars for years and I have never come across a stuck plug. The two things that are prevalent in my mind right now are anti-sieze and making sure of a torque value. A new drain plug will definitely be needed.
For the time being, any suggestions on how to get this one out? I am a tool maker (machinist) and I am no stranger to getting a stuck bolt out. I really don't want to have to drill this thing, but I don't know what else to do. Anything I may have missed?
Old Oct 12, 2008 | 05:15 PM
BobbyG123's Avatar
BobbyG123
A pipe wench?or
Center punch, then LH drill bit?
Hope you get it out
Later,
Bobby
Old Oct 12, 2008 | 05:57 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by BobbyG123
A pipe wench?or
I don't think there's enough clearance, between the drain plug and the engine cradle, for any of these tools to work.
I would try hitting the edge of the head with a sharp chisel, in the right direction to try to loosen the plug.
The oil pan is a two piece design, and the bottom part, with the drain plug, is not very hard to remove. Then you can use the above mentioned tools to get the plug out. Good luck, and let us know how you make out.
Old Oct 12, 2008 | 06:20 PM
2004TTZ06's Avatar
2004TTZ06
Weld another bolt to the head of that one, if you dont have a welder go to your local mufler shop.
Old Oct 12, 2008 | 06:32 PM
J S Machine
This product got it out finally. Thanks for the suggestions.
http://www.amazon.com/dp/B0000CCXVZ?...0&linkCode=asn
Old Oct 12, 2008 | 08:04 PM
Quicksilver Vert 01
Glad you got it out. There's a right tool for every job. You just need to find it.
Old Oct 12, 2008 | 08:34 PM
TEXHAWK0's Avatar
TEXHAWK0
I always wondered if those sockets really worked.
Guess they do! It does make you wonder why someone would put a drain plug in that tight. With the rubber gasket, there is no reason it should be that tight.
Old Oct 12, 2008 | 09:13 PM
MagRedConv's Avatar
MagRedConv
The bolt out is a great tool.
Old Oct 12, 2008 | 09:14 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
or hopefully turning in the right direction.
Old Oct 13, 2008 | 09:51 AM
aggiestckl's Avatar
aggiestckl
another method I used is to drop the pan, drill through the stripped bolt push another nut and bolt through, tighten it as much as possible, and than turn it with the new bolt i just inserted. Worked well
Old Oct 13, 2008 | 01:49 PM
K RIPPER's Avatar
K RIPPER
That tool works great, execptional on studs ,a larger version is used on heavy trucks to remove damaged front wheel studs.A trick I learned recently for stuck fasteners heat bolt/nut to as hot as application will allow place a wax candle against the bolt/nut while still hot wait few min. wax will work into threaded area and allow removal.Used this method once on oil galley plugs on BB worked great
Old Oct 13, 2008 | 03:43 PM
tabbruzz's Avatar
tabbruzz
Vise grips are your friend
To Oil Pan Drain plug bolt head stripped. Please Help
