RESERVE FUEL, how much fuel is left?
Old Oct 13, 2008 | 08:54 PM
FlyboyZR1's Avatar
FlyboyZR1
Default RESERVE FUEL, how much fuel is left?
I drove my car last night and after shutting it off it had under 1/4 tank but the needle was not yet on the E. Well I drove it today and right away the needle was on E, and it said RESERVE FUEL. I went to the gas station and all it would take was 14.5 gallons.
Does this seem right? Does the needle tend to drop quickly the last 1/4tank? It seems to me like it should have taken more than 14.5 gallons...
Old Oct 13, 2008 | 08:57 PM
Shore's Avatar
Shore
Mine does the same thing...bam gone.
Old Oct 13, 2008 | 08:58 PM
ZeeOSix's Avatar
ZeeOSix
If the fuel tanks are low and you fire up the car it takes a little while for the fuel system and gauge reading to balance out.
I find in my 02 Zee that there is about 2.5~3 gallons left (~50 mile range) when the 'reserve fuel' message comes on.
Old Oct 14, 2008 | 07:48 PM
ZeeOSix's Avatar
ZeeOSix
My info in post #3 above is based on filling up the tank very shortly after "Reserve Fuel" comes on. And it does come on when the fuel gauge needle is just starting to touch the red area on the "E" mark on the gauge.
Old Oct 14, 2008 | 09:27 PM
Goody's Avatar
Goody
Were you parked at an angle? This is known to throw off readings.
Old Oct 15, 2008 | 12:53 AM
dberry08's Avatar
dberry08
I had the samething happen on Sunday. I was able to put 16 gallons in, so I think I remember reading it is a 18-19 gallon tank, so about 3 gallons left with the reserve fuel light comes on. Somone can correct me on the actual size of the fuel tank if i'm off.
Old Oct 15, 2008 | 02:02 AM
striper's Avatar
striper
When I've hit the reserve message the most I usually take is a little over 15 gallons.
Old Oct 15, 2008 | 05:50 AM
Joy of 6's Avatar
Joy of 6
Me too. If I hit a station right away it will be 15 plus gallons
Old Oct 15, 2008 | 06:38 AM
byte_me's Avatar
byte_me
because most of the time the fuel gauge is somewhat finicky (on my 97 anyway)- I rarely let it get below 1/4 tank before I fill her up. On the occasion I have gone from a little more then 1/8th a tank when turning off- to flat out "low fuel" the next turn on...
Old Oct 15, 2008 | 08:04 AM
yankeevetteconvert's Avatar
yankeevetteconvert
A "cold" tank of fuel will give you a lower fuel gauge reading.That is why you saw a lower reading in the morning than the night before.
Old Oct 15, 2008 | 12:39 PM
hotwheels57's Avatar
hotwheels57
Running your fuel tank that low is a great way to damage the fuel pump...
Old Oct 15, 2008 | 02:22 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by 8VETTE7
Owners manual for an 04 says 18.0 Gals.
The 2001 and 2002s take 18.5 gallons. GM redesigned the fuel tanks (03 or 04?) and the total capacity went down some.
ZeeOSix's Avatar
ZeeOSix
I've heard some say yes and some say no. It could be related to if it's the old or new fuel tank design.
Old Oct 15, 2008 | 02:47 PM
hotwheels57
I tried to download the owners manual PDF file from GMPARTSHOUSE, but it just locked up.
I found this...
http://www.aa1car.com/library/fuel_pump.htm
Old Oct 15, 2008 | 05:48 PM
CTSV OWNER's Avatar
CTSV OWNER
Maybe I'm a fool but I usually drive until RESERVE is displayed. Then when LOW FUEL message comes on I have about 40 miles before I get nervous. But hey what do I know, my car only has 246,000 miles on it. (original fuel pump that will quit tommorrow now that I've posted this) I'm only getting 23 mpg due to the 3:15 gears and the TCC valve in the trans not always working properly.
Dave
Old Oct 15, 2008 | 09:46 PM
johninar's Avatar
johninar
I agree with the post above concerning the fuel pumps.
Gas keeps the pumps cool. I'd avoid running too low. Your fuel pumps will last longer.
Just my $0.001 (adjusted for market losses)
Old Oct 18, 2008 | 04:26 PM
GettnBetter's Avatar
GettnBetter
In my 2000 I'd estimate about 2-3 gallons are left in the tank at reserve, thats assuming the tank really holds 18 gallons.
Sometimes though, especially in traffic or in some cases of deceleration the needle will go from 1/2 or 1/4 to Reserve and won't reset until I shut off the car for some time. Not sure why that happens.
To RESERVE FUEL, how much fuel is left?
Old Oct 18, 2008 | 06:50 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When I fill up I usually wait until the light comes on. According to my records, I usually put in around 16.5 gallons give or take half a gallon. I have put in 18.984 gallons on one tank. I must have been running on fumes that time. I did manage 484.5 miles on that tank.
Old Oct 18, 2008 | 06:51 PM
427CPE's Avatar
427CPE
I want to say I figured 60 miles at RESERVE and 20 or so LOW FUEL
Old Oct 18, 2008 | 09:46 PM
ZeeOSix's Avatar
ZeeOSix
?? ... what light? I don't think there is a 'low fuel' light on a C5.
