03 Automatic how much power will it handle?
Old Oct 14, 2008 | 10:35 PM
hotrodtp's Avatar
hotrodtp
Default 03 Automatic how much power will it handle?
A friend of mine is trying to talk me into letting him fabricate a twin-turbo set up for my C/5. My only problem is that, I don't know how much power the trany will hold up to?? I would like to put down approx 550-600 at the wheels. So will it last??
Old Oct 15, 2008 | 01:31 AM
Bluefire's Avatar
Bluefire
I have an 03 A4 and I highly doubt that the stock tranny will hold long under 500 - 600 rwhp. I want to add heads and a cam so I am hoping Rodney will chime in and give us the real scoop. My best guess is the that the stock tranny is good up to about 400 - 450rwhp
Rodney?
If you plan on doing some hard launches with it you might also consider upgrading the rear gears with at least a hardened output shaft and a diff/trans brace.
HTH
Old Oct 15, 2008 | 10:42 AM
kromberg's Avatar
kromberg
The 4L60E will handle about 10 rwhp over stock
Old Oct 15, 2008 | 10:56 AM
hotrodtp's Avatar
hotrodtp
I figured the tranny was the weak link. It shifts way to SOFT>>>>
Old Oct 15, 2008 | 04:34 PM
Andrew@MarylandSpeed's Avatar
0Andrew@MarylandSpeed
Former Vendor
I don't think you'll be able to expect the stock tranny to last long at all with that kind of power. While your Corvette is much lighter than my GTO, my stock 4L65E was starting to take a dump on me at 20k miles.... 17k miles after the Magnacharger was installed. The past 10k miles have included a good bit of drag racing at the tracks, cutting low 1.5 60' times. The car has been putting down around 500 rwhp for the past 10k miles and the trans wasn't willing to take much more abuse.
You power won't be as brutal down low as mine, but your 2-3 and 3-4 clutches probably aren't going to hold up for too long with that kind of torque and power. Be ready to contact Frank at Performabuilt for a nicely-built transmission if you do decide to let your buddy twin-turbo your car
Old Oct 15, 2008 | 05:36 PM
David426's Avatar
David426
4l60e is a piece of you know what.. My 99 coupe crapped out at 40k miles with 316rwhp which is around 370hp at the crank.. Have Rodney at RPM build a level IV
Old Oct 15, 2008 | 07:38 PM
hotrodtp's Avatar
hotrodtp
Point Taken!! I really appreciate all of the input. I figured it wouldn't take it. Like I said it is just so soft, and all I have now is Vararam & Bassani Mufflers. Going to explore some other options. I have the car for sale anyway??
Old Oct 16, 2008 | 03:47 PM
dankhts's Avatar
dankhts
I think you're being generous... it'll only handle 340 hp....
next time mine fails, it'll get replaced with an RPM tranny....
Old Oct 16, 2008 | 05:12 PM
chaase's Avatar
chaase
St. Jude Donor '12
Mine has held up to 420rwhp pretty well, but 500-600 will probably break it.
Old Nov 15, 2008 | 12:59 AM
usmcrtr's Avatar
usmcrtr
SC 98/A4/3.15 with 54k 405rwhp zero problems
Old Nov 15, 2008 | 08:21 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Mine has 420+ RWHP and it has worked perfect 25K plus miles. I also still have the stock converter.
Old Nov 15, 2008 | 05:01 PM
verano29's Avatar
verano29
Old Nov 15, 2008 | 05:02 PM
verano29's Avatar
verano29
It's really easy to firm up the shift...bump up the line pressure. Also you can install a shift kit.
Old Nov 15, 2008 | 05:11 PM
verano29's Avatar
verano29
Also remember that with a manual the weak point is the cluctch....and a good clutch isn't cheap...nor is the install trivial. Plus this is the 21st century....manual transmissions are sooooo old school.
Rebuilding an automatic trans is pretty simple. There are a host of kits out there that can handle the kind of power you're talking about. I wouldn't worry about it. Install your turbos, when/if the transmission fails rebuild it.
Old Nov 15, 2008 | 05:15 PM
Corvette Don's Avatar
Corvette Don
I think what you are saying is completly opposite of what it should be
Auto trans are not something I would EVER rebuild and I have had every bit of my car apart along with my buddies C6 (stall, clutch, heads, cam, you name it).
A good clutch is cheap ($400) and they are not all that bad to change out.
To 03 Automatic how much power will it handle?
