changing rims question
Old Oct 15, 2008 | 05:23 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Default changing rims question
I'm changing out 1 set of OEM rims for another set of OEM rims and the air pressure sensors will need to be changed out. Is there a crimping tool needed to do this or not?
Old Oct 15, 2008 | 05:28 PM
Finja's Avatar
Finja
No its bolted in. The stem of the sensor sticks through the rim from the inside and a nut goes on the out side. Make sure you do not tighten them doen tomuch cause they will break!
Old Oct 15, 2008 | 05:51 PM
2EZ 2SPD's Avatar
2EZ 2SPD
Good info thank you
To changing rims question
