What did I do...HELP
1. Replaced the Battery for a better stronger battery.
2. Replaced the key cylinder. I don't think it was the part of the solution but it takes I out of the equation for future troubleshoot.
3. Replaced the theaft deterant relay.
4. Did the 11 minute 30 second cycle of the start switch.
http://forums.corvetteforum.com/show....php?t=2159975
BILL CURLEE's THREAD TO FIX YOUR IGNITION SWITCH.
http://forums.corvetteforum.com/show...tion+c5+switch
I just fixed my Car this way last night!!
1, Load test the battery, pep boys, advance, and autozone usually don't charge for this service.
2, Make sure the batt cables are clean and tight, at the battery, ground, starter lug, and uh fuse block.
3, Clean all the grounds, there are 9 spots. SEE BELOW.
If that all checks out then you may need to look at the ig switch, starter solenoid, tdr, etc.
As for the cables that look uneven , the cables coming from the tdr, and the alt have a fusible link in them that is wider in spots then the cable. But if the bat cables look bad they probably should be replaced, if they are corroded in between the strands, they will build up resistance.
Good Luck
